In tf2_ros/src/transform_listener.cpp line 123 in TransformListener::subscription_callback_impl(...) the call buffer_.setTransform returns a boolean. If I've read things right it appears like that the return value should be checked, and handled in some way (error message if false??)
Originally posted by robotiqsguy on ROS Answers with karma: 21 on 2013-12-04
In general it's very unlikely to happen and there's not much else to do about it if it fails.
The only thing I could see is to add a debug output there if it fails. I'd merge a patch for that.
Originally posted by tfoote with karma: 58457 on 2013-12-07
Comment by robotiqsguy on 2013-12-07:
I think that it is reasonable to add debug output in there. If for some reason it does fail I think its better to know about it than not.
