Hello everyone,
Currently i'm taking care of a project from another student, who just vanished since two months - but my dep still needs the project finished. So i have to dig into the system fast und get the whole simulation to run.
The setup is - as far as i can see - an ROS Hydro server with a husky as robot. The client from gazebo is used to view the simulation. The problem is, that i only get the husky to move via the rostopic command, but not through code. The goal of the simulation-setup is to run java code, that controls the robot depending on the output of the sensors. I already understood that rosjava will be needed, but this isn't installed on the server - i will have to take care of that.
So, my question is - how can i control the robot via c++ code? In the tutorials i only got information about how to send messages and about the filesystem and so on. Did i missread the whole thing? It would be really nice if someone could dip my face into it :D
Thanks in advance, Nathan
Originally posted by Nathan Schwarz on ROS Answers with karma: 3 on 2013-12-02
You can publish to a ROS topic from C++ code. Please refer to this tutorial for details. You should be able to do the same from any of the other languages implementing ROS clients, like Python or Java.
Originally posted by Adolfo Rodriguez T with karma: 3907 on 2013-12-02
Comment by Nathan Schwarz on 2013-12-05:
Thanks, i got the entire tutorial wrong, i think :D I will reread the whole thing, thanks for the help!
