18
Typically Mars rovers use wheels and not tracks. I guess Spirit would have better chances getting out of that soft soil should it have tracks. In general, Mars surface structure is not known in advance, so it seems wiser to be prepaired for difficult terrain and so use tracks.
Why do Mars rovers typically use wheels and not tracks?
  • $\begingroup$ There is also another question on the subject of wheels vs threads $\endgroup$
    – Jakob
    Nov 28, 2012 at 14:01
  • $\begingroup$ @Jakob: Yeap, I've seen that one, but it just lists common considerations, not specific to an application. $\endgroup$
    – sharptooth
    Nov 28, 2012 at 14:06
  • $\begingroup$ This might be of interest: researchgate.net/publication/… $\endgroup$
    – guero64
    Sep 21, 2022 at 19:49
3 Answers 3
11
I think the surface of mars was pretty well known by the time Spirit / Op landed.
The rocker-bogie system allows the robot to climb over obstacles up to twice the diameter of the wheels, while avoiding springs completely. Springs could cause the chassis to tilt on uneven terrain. Watch this video: https://www.youtube.com/watch?v=ON1zLBvYKRI, and imagine how much the chassis would tilt if it were suspended by a spring-based system or if the wheels were attached to each other by treads.
The Jet Propulsion Laboratory has a good video on this, actually. http://www-a.jpl.nasa.gov/video/index.php?all_videos&id=932
  • $\begingroup$ Well, then why would the rover get stuck? $\endgroup$
    – sharptooth
    Nov 29, 2012 at 11:32
  • $\begingroup$ I didn't say it would never get stuck. I answered the question: "why would they use rocker-bogie instead of treads?" $\endgroup$ Nov 29, 2012 at 16:04
11
There are multiple reasons wheels may be prefered over treads. The main ones that apply to the mars rovers I would put as:
  • Mass is a critical property, especially for space exploration missions. Treads are generally heavier than wheels.
  • Treaded vehicles only support skid steering and are thus less precise to manouver. They also take more power when turning.
  • For space exploration simplicity is key. A wheel has less moving parts that can get damaged.
  • Material properties also have to be taken into account to fit the environmental conditions.
This may not be the biggest reason, but I would imagine that for space vehicles like this, wheels are easier to stow for launch and then deploy for landing.
