According to the following question:
http://answers.ros.org/question/91111/rgbdslam-in-ros-hydro/
I changed in my manifest.xml the line
  <depend package="pcl"/>
to
  <depend package="pcl_conversions"/>
This seems working for me. Thanks for the hint with migration of pcl with pcl_conversions.
And after the ugly thing of adding the old header file OctomapROS.h in the folder /opt/ros/hydro/include/octomap_ros/, this worked, too.
But now I get some conversion errors:
.../src/rgbdslam_freiburg/rgbdslam/src/graph_mgr_io.cpp:542:67: error: request for member ‘toSec’ in ‘node->Node::pc_col.boost::shared_ptr<T>::operator-> [with T = pcl::PointCloud<pcl::PointXYZRGB>]()->pcl::PointCloud<pcl::PointXYZRGB>::header.pcl::PCLHeader::stamp’, which is of non-class type ‘uint64_t {aka long unsigned int}’
 .../src/rgbdslam_freiburg/rgbdslam/src/graph_mgr_io.cpp:881:42: error: conversion from ‘uint64_t {aka long unsigned int}’ to non-scalar type ‘ros::Time’ requested
 .../src/rgbdslam_freiburg/rgbdslam/src/graph_mgr_io.cpp:882:32: error: cannot convert ‘ros::Time’ to ‘uint64_t {aka long unsigned int}’ in assignment
  .../src/rgbdslam_freiburg/rgbdslam/src/graph_mgr_io.cpp:884:32: error: cannot convert ‘ros::Time’ to ‘uint64_t {aka long unsigned int}’ in assignment
and so on. Similiar conversion errors with ccny_rgbd and viso2_ros after changing from pcl to pcl_conversions.
So I am pretty sure something went wrong with my migration from pcl to pcl_conversions. Or is it maybe more then just editing the manifest.xml / package.xml from
<depend package="pcl"/> to <depend package="pcl_conversions"/>
Originally posted by RodBelaFarin on ROS Answers with karma: 235 on 2013-11-29
Comment by pinocchio on 2014-03-26:
@RodBelaFarin Thanks for sharing this. I am doing the similar thing with you. However, as a beginner, I do not know how to do exactly. Could you please give me a step by step instruction? (i.e. where can I find the old header file OctomapROS.h) I appreciate it. Many thanks.
@RodBelaFarin Also, Could you please tell me which workspace you install the package? I use catkin workspace in hydro, but some guys say that only rosbuild ws is available for this package. However the rosbuild is for fuerture.http://wiki.ros.org/ROS/Tutorials/InstallingandConfiguringROSEnvironment
Comment by RodBelaFarin on 2014-03-26:
old octomapROS.h: https://code.google.com/p/alufr-ros-pkg/source/browse/branches/octomap_stacks-groovy-devel/octomap_ros/include/octomap_ros/OctomapROS.h?r=3074
In the end I was NOT able to finish with RGBDSLAM. If you "just" need the 3D pointcloud, I recommend to switch to CCNY. It is much easier.
Comment by pinocchio on 2014-03-27:
Hi @RodBelaFarin, thanks for your reply. I read the paper of CCNY, but I am not sure whether this method can generate a map of the indoor environment. There are some results of mapping on the paper, but maybe no algorithm shown. So, how can I achieve mapping use this package? Many thanks.
Hi @RodBelaFarin, I tried CCNY by your recommandation, but some errors occur, as shown in http://answers.ros.org/question/145411/error-on-installing-ccny-package-on-hydro/. Could you please tell me how to intall in on hydro?
Comment by RodBelaFarin on 2014-03-27:
http://wiki.ros.org/ccny_rgbd?distro=groovy use the quick usage guide from there. the last step "rosservice call /save_pcd_map /home/your_user_name/my_map.pcd" shows you how to save the 3D pointlcloud from your environment.
The answer is on the migration-site (http://wiki.ros.org/hydro/Migration#PCL):
for every conversion error you need to make little changes in the specific lines in the code.
1.
#include <pcl_conversions/pcl_conversions.h>
2.
pcl_cloud.header = pcl_conversions::toPCL(pc2->header);
Originally posted by RodBelaFarin with karma: 235 on 2013-11-30
