I am running a robot pc (NUC) with ros-fuerte and my laptop with ros-hydro. I want to run the main nodes on the robot and the debugging nodes like rqt_plot and some hand made GUIs that use services on my laptop. Following the instructions from the ros wiki on NetworkSetup and MultipleMachines everything gets started and I can see all services and topic doing rostopic/rosservice list on both machines. But if I start my debugging nodes on the laptop (the robot fuerte is running the roscore) the topics and services from the robot seem not reachable. It just doesn't work, I mean there is no output saying connection failed or anything. Only if I try rosservice info <my_service> it says:
Node: /motor_control URI: rosrpc://NUC:47241 ERROR: Unable to communicate with service [/motor_control/SpeedLeftGainControl], address [rosrpc://NUC:47241]
Can this be due to discompabilities between fuerte and hydro? I have no other idea, since everything else works like described.
Originally posted by rilke on ROS Answers with karma: 35 on 2013-11-22
As long as the specific messages have not been changed between the two ROS distributions (which is only rarely the case) it should be work fine. One likely problem you are running into is that one of your computers can not resolve the other one without some more hints. Please read http://wiki.ros.org/ROS/NetworkSetup and see if setting ROS_IP / ROS_HOSTNAME makes it work for you.
Originally posted by Dirk Thomas with karma: 16276 on 2013-11-22
Comment by rilke on 2013-11-25:
I tried to set either ROS_IP or ROS_HOSTNAME but it did only produce further errors. What solved it for me was to define the mapping between ip and hostname in /etc/hosts
Comment by Dirk Thomas on 2013-11-26:
Since the mapping in your hosts file worked it is very likely that you have set the ROS_IP / ROS_HOSTNAME variables wrong. You might either want to keep using the host file approach or try getting the environment variable to work. May be this similar questions provides you with the necessary hints: http://answers.ros.org/question/9915/ros-mutiple-machine/
