Hi everyone, I am a newbie and was trying to follow the tutorial from here:moveit.ros.org/wiki/PR2/Rviz_Plugin/Quick_Start and when I tried launching roslaunch pr2_moveit_config demo.launch, I would get this message below:
All is well! Everyone is happy! You can start planning now!
[ INFO] [1385051476.430164298]: Loading robot model 'pr2'... [ INFO] [1385051481.184719538]: Loading robot model 'pr2'... [ INFO] [1385051482.547427811]: Loading robot model 'pr2'... [rviz_cehd_1050011_7612_1188156060-6] process has died [pid 7687, exit code -11, cmd /opt/ros/hydro/lib/rviz/rviz -d /opt/ros/hydro/share/pr2_moveit_config/launch/moveit.rviz __name:=rviz_cehd_1050011_7612_1188156060 __log:=/home/willi/.ros/log/50fcfb64-52ca-11e3-b7fb-0024e8bf7cc6/rviz_cehd_1050011_7612_1188156060-6.log]. log file: /home/willi/.ros/log/50fcfb64-52ca-11e3-b7fb-0024e8bf7cc6/rviz_cehd_1050011_7612_1188156060-6.log*
I searched around and it is a similar message but not exactly the same on this one://answers.ros.org/question/75769/ros-moveit-pr2-demo-launch-fails/. It fails at the end after saying all is well etc.
I just reinstall Ubuntu 12.0.4 64 bit because I thought my previous Ubuntu 12.0.4 32 bit is not working (always getting the same error 11) so I just freshly installed ROS Hydro, MoveIt and PR2 full and it is still failing and it's only a tutorial.
Can anyone give me an insights on what to do next? Thanks a lot.
Originally posted by dragowill on ROS Answers with karma: 5 on 2013-11-21
This is a total guess, but I experienced similar crashes with MoveIt on various machines and it turned out to be RViz rather than MoveIt that is crashing. This seems to happen more often when RViz is trying to use hardware acceleration, so try turning telling RViz to use software rendering only before launching the PR2 MoveIt demo file like this:
$ export LIBGL_ALWAYS_SOFTWARE=1
$ roslaunch pr2_moveit_config demo.launch
--patrick
Originally posted by Pi Robot with karma: 4046 on 2013-11-21
Comment by dragowill on 2013-11-21:
Hi Patrick, thanks for responding. That seems to work for launching pr2 demo.launch now. However, every time I close Rviz that error message would show and have to use ctrl c to get out of it from the terminal. Do you think it's a good idea to put LIBGL_ALWAYS_SOFTWARE=1 in .bashrc? Thanks. --willi
Comment by Pi Robot on 2013-11-21:
Glad that got you going. I also have to Ctrl-C to exit MoveIt completely after closing RViz--not sure if others are experiencing the same thing. I have "export LIBGL_ALWAYS_SOFTWARE=1" in my .bashrc since I was getting tired of RViz crashing. You can do an "unset LIBGL_ALWAYS_SOFTWARE" in a given terminal if you want to override it on the fly.
Awesome. Thanks! and I just realized that it is mentioned on top of this page:wiki.ros.org/rviz/Troubleshooting and found out that my laptop has Intel Mobile 4 Graphics Controller. so I am definitely will put it in my .bashrc.
