I'm totally a beginner in ROS & Robotics .. I have installed ROS Hydro and set up my workspace + sandbox.
then i started to create enclosure_escape package with 3 dependencies
$ roscd
$ cd sandbox
$ roscreate-pkg enclosure_escape roscpp kobuki_msgs geometry_msgs
now I have to create my c++ code in src folder .. lets say enclosure_escape.cpp which contains the following code ..
//include libraries
#include <kobuki_msgs/BumperEvent.h>
#include <geometry_msgs/Twist.h>
#include <ros/ros.h>
//define the bumperCallback function
void bumperCallback(const kobuki_msgs::BumperEvent bumperMessage)
  ROS_INFO("bumper hit. value = [%d]", bumperMessage.bumper);
//ROS node entry point
  ros::init(argc, argv, "turtlebot_test_node");
  ros::NodeHandle n;
  ros::Subscriber bumperSubscriber = n.subscribe("/mobile_base/events/bumper", 100, bumperCallback);
  ros::Publisher velocityPublisher = n.advertise<geometry_msgs::Twist>("cmd_vel_mux/input/teleop", 1);
  //create a Twist message to publish the velocity
     geometry_msgs::Twist velMessage;
     velMessage.linear.x = 1.0;
     velMessage.angular.z = 0.0;
  //publish the message
  velocityPublisher.publish(velMessage);
  ros::spin();
  return 0;
now the Question comes .. how to run this on turtlebot simulator?
Originally posted by adelali on ROS Answers with karma: 1 on 2013-10-25
Comment by choog on 2014-06-06:
on your ros::Publisher velocityPublisher = n.advertise<geometry_msgs::Twist>("cmd_vel_mux/input/teleop", 1); line why do you specify ("cmd_vel_mux/input/teleop", 1) in your code? what is this doing?
To run this with a TurtleBot in simulation you just have to run it on the same network with the same ROS Master and it will communicate over ROS.
Originally posted by tfoote with karma: 58457 on 2014-03-26
