I'm running hydro and switching over from new rosbuild to using catkin. I read through the catkin conceptual overview and tutorials but have trouble implementing.
I'm trying to get the tilting hokuyo set up. I 'catkinized' the hrl_hardware_drivers but having trouble with the hrl_lib. It wasn't included in the package so I found it externally. When I run:
rosrun hrl_hokuyo hokuyo_processing.py
It goes me the error:
src/hrl_hokuyo/hokuyo_processing.py", line 43, in import hrl_lib.transforms as tr ImportError: No module named hrl_lib.transforms
I believe the cmakelist and package.xml file was edit appropriately to include hrl_lib. I want to do it right and not just add the hrl_lib folder into the directory.
Thanks!
Heres is the cmake
project(hrl_hokuyo)
find_package(catkin REQUIRED COMPONENTS hokuyo_node sensor_msgs rospy hrl_lib)
set(EXECUTABLE_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/bin)
set(LIBRARY_OUTPUT_PATH ${PROJECT_SOURCE_DIR}/lib)
catkin_package(
    DEPENDS hokuyo_node sensor_msgs rospy hrl_lib
    CATKIN_DEPENDS # TODO
    INCLUDE_DIRS # TODO
    LIBRARIES # TODO
Here is the package.xml
<package>
  <name>hrl_hokuyo</name>
  <version>1.0.0</version>
  <description>Python class that uses hokuyo_node from ros-pkg to get scans from
  UTMs and player to get scans from URGs.</description>
  <maintainer email=""></maintainer>
  <license>New BSD</license>
  <url type="website"></url>
  <buildtool_depend>catkin</buildtool_depend>
  <build_depend>hokuyo_node</build_depend>
  <build_depend>sensor_msgs</build_depend>
  <build_depend>rospy</build_depend>
  <build_depend>hrl_lib</build_depend>
  <run_depend>hokuyo_node</run_depend>
  <run_depend>sensor_msgs</run_depend>
  <run_depend>rospy</run_depend>
  <run_depend>hrl_lib</run_depend>
</package>
Edit #1
I'm still having trouble with it. Is the hrl_lib package just a folder with the python files in it? This doesn't feel right since there are other folders with the library as well. Here is my structure:
/path_to_workspace/
    /src
        /hrl_hokuyo
            /setup.py
            /src
                /hrl_hokuyo
                /hrl_lib
Thanks for the quick response and breaking it down for me.
Edit#2
I didn't edit it much except just setting the path.
from distutils.core import setup
from catkin_pkg.python_setup import generate_distutils_setup
d = generate_distutils_setup(
    packages=['hrl_lib'],
    package_dir={'/path_to_directory_containing_hrl_lib/': 'src'}
setup(**d)
Originally posted by pwong on ROS Answers with karma: 447 on 2013-10-22
Comment by pwong on 2013-10-22:
Thanks for the comment and telling me the preferred method to posting responses!
Comment by William on 2013-10-22:
Can you post your setup.py? It is likely that you are not declaring your packages correctly.
Another option is for you to push this to github (or something similar) and point me to it.
I'll work on putting this onto github
I think you have the package_dir wrong, see my edit to my question and this: http://docs.python.org/2/distutils/setupscript.html#listing-whole-packages
In order to export python libraries you need to do two things:
  • Setup a setup.py file describing which Python packages your package has
  • Call the catkin_python_setup() macro in your CMakeLists.txt
Reference: http://docs.ros.org/api/catkin/html/user_guide/setup_dot_py.html
The setup.py should be in the root of your package and look like this:
    packages=['mypkg'],
    package_dir={'': 'src'}
setup(**d)
Where...
    packages=['mypkg'],
'mypkg' is the name of the python package you want, in your case probably 'hrl_lib', and...
'src' is the folder in your package where you keep these packages, so your folder structure would be:
/path/to/my/package
                   /setup.py
                   /src
                       /hrl_lib
                               /__init__.py
And in your CMakeLists.txt you need to call before catkin_package(...):
Also, get rid of these lines:
This was someting that rosbuild had you do, but you shouldn't do this in catkin.
EDIT:
I would expect your setup.py to look like this:
    packages=['hrl_hokuyo', 'hrl_lib'],
setup(**d)
Originally posted by William with karma: 17335 on 2013-10-22
Comment by pwong on 2013-10-23:
Without the package path at package_dir it works. Thank you!
