I am using osc / OpenSUSE OBS to build RPM packages of catkin for OpenSUSE. In my .spec file, I am doing something like this (for example, with the message_generation package):
%setup -q -c -n workspace
mv * message_generation
mkdir src
mv message_generation src
%build
CMAKE_PREFIX_PATH=/usr catkin_make_isolated --install
The issue I am currently having is that the way the code is written for catkin, my message_generation.pc file in the workspace/install_isolated directory looks like this:
Description: Description of message_generation
Version: 0.2.10
Cflags:
Libs: -L/home/abuild/rpmbuild/BUILD/workspace/install_isolated/lib
Requires: gencpp genlisp genmsg genpy
I would like Libs to be -L/usr/lib, where I am planning on moving the lib directory, but instead, I am seeing that build environment path, which shouldn't happen. How can I go about doing this?
Originally posted by duffany1 on ROS Answers with karma: 173 on 2013-10-21
You need to use the --install-space argument to install into /usr/lib instead of the default install_isolated.
Originally posted by tfoote with karma: 58457 on 2014-01-15
