What I want to do: I want to say any text :) I try to use sound_play and say.py. I try to launch soundplay_node using
roslaunch sound_play soundplay_node.launch
And I have the following error:
 File "/opt/ros/groovy/stacks/audio_common/sound_play/scripts/soundplay_node.py", line     43, in <module>
   from sound_play.msg import SoundRequest
ImportError: No module named sound_play.msg
What I shall do?
Originally posted by pelment on ROS Answers with karma: 47 on 2013-10-18
Comment by Sergiiio on 2021-07-26:
I am new at this. How can i compile sound play node?
Did u compile the sound play node to generate the respective messages?
Originally posted by makokal with karma: 1295 on 2013-10-18
Comment by pelment on 2013-10-18:
Hm, I did it once and forgot about the fact that I have a error with root access. Thank you, I built it again and now it works!
