I have been running ardrone_autonomy with an AR.Drone1.0 and it has been working great. Today I bought an AR.Drone2.0 and assumed that my code would work out of the box. Unfortunately ardrone_autonomy ardrone_driver throws this error over and over again:
One option (0) is not a valid option because its size is zero
[Navdata] Checksum failed : 1006 (distant) / 34055 (local)
Tag 12504 is an unknown navdata option tag
Is there something I need to change in the code / launch file to make it compatible with the AR.Drone2.0?
I should also mention (though I don't think it's relevant) that I modified ardrone_autonomy to make it catkin compatible.
Originally posted by ounsworth on ROS Answers with karma: 37 on 2013-10-15
You have to look for the drone firmware. it must be 2.3.3
look here https://github.com/AutonomyLab/ardrone_autonomy/issues/69
we are all waiting for the new sdk from parrot
Originally posted by mmyself with karma: 138 on 2013-10-16
Comment by ounsworth on 2013-10-29:
Worked like charm, firmware was very easy to downgrade. Thanks!
