I managed to resolve the problem. The easier way is to add the header file OctomapROS.h in the folder /opt/ros/hydro/include/octomap_ros/. In such a way though it is a deprecated file the rgbdslam can find what it needs. For the pcl library I used the pcl_conversions to convert all headers of point cloud (where needed) from pcl type to ros msg and vice versa, as explained in the hydro migration page.
Now the rgbdslam works fine!
EDIT: can someone mark this answer as correct? (I can't due to lack of karma)
Originally posted by Tirjen with karma: 808 on 2013-10-22
Comment by AHornung on 2013-10-22:
Just keep in mind that the header OctomapROS.h was already deprecated for groovy and is gone for good since hydro. The cleanest solution would be to fix RGBD-Slam such that it's no longer including it.
Comment by RodBelaFarin on 2013-12-02:
@Tirjen Could you maybe upload your new source files? Cause it is a never ending task to change the codes line by line. You can send me per mail or share it here with everyone, maybe ;)
Mail: patrick dot wiesen at gmail dot com
Comment by Tirjen on 2013-12-15:
Unfortunately I cannot do that because I'm not using anymore the pc on which I installed the rgbdslam. If I will have access again to that pc I will do it! Anyway I assure you that doing it by yourself is a 10-minutes work! ;)
Comment by Tirjen on 2014-03-09:
As Jiangtao says, the problem could be related to the topics you are listening to. Did you check it?
Comment by TSC on 2014-03-26:
Having the same problem as @lguodongustc. any idea what ros topics should be listened? It gives me this warning:
WARNING: [/home/tsc/catkin_ws_hydro/src/rgbdslam_freiburg/rgbdslam/launch/kinect+rgbdslam.launch] unknown attribute 'no-launch-prefix'
Comment by pinocchio on 2014-03-26:
@TSC @lguodongustc What kind of workspace do you install the RGBDSLAM package, catkin or rosbuild? Also, do you install arm_navigation stack and the octomap_server? It says that they are deprecated in Groovy and Hydro.
