Is there already a way to forward / aggregate multiple topics to a single topic?
I tried remapping with rostopic echo, but found that the last remapping argument takes precedence. Example in bash:
# Spin up unique publishers
rostopic pub -r 5 /test/a std_msgs/Float64 "data: 0.0" &
rostopic pub -r 5 /test/b std_msgs/Float64 "data: 20.0" &
# Echo with remapping
rostopic echo /test/c /test/c:=/test/a /test/c:=/test/b
The output shows '20.0', meaning b's data is the only one getting through.
For the time being, I wrote a script to aggregate the topics: topic_aggregator.py
Originally posted by eacousineau on ROS Answers with karma: 174 on 2013-10-14
Will topic_tools/relay do what you want?
Originally posted by Dan Lazewatsky with karma: 9115 on 2013-10-15
Comment by eacousineau on 2013-10-15:
Seems like it only handles a single topic. I tried out topic_tools/mux, which handles multiple topics, but running rostopic echo only showed '0.0'. Will look a little more into it.
Comment by dornhege on 2013-10-15:
mux switches between topics, it doesn't merge them.
Comment by Dan Lazewatsky on 2013-10-15:
If I understand your question correctly, two instances of relay should do what you want, one that does /test/a -> /test/c and one that does /test/b -> /test/c
Comment by eacousineau on 2013-10-16:
Ah, that works. Thank you!
My intuition says no, because that will be two distinct connections.
Originally posted by dornhege with karma: 31395 on 2013-10-14
That makes sense.
