When I tried to launch the OpenNI Kinect driver on PR2, I do:
roslaunch /etc/ros/openni_head.launch
And then I got the following error message:
unused args [name] for include of [/opt/ros/hydro/share/openni_launch/launch/includes/manager.launch]
Nothing was started.
Here is the openni_head.launch file. I think that the problem is from line 47~50:
  <include file="$(find openni_launch)/launch/includes/manager.launch">
    <arg name="name" value="$(arg manager)" />
    <arg name="debug" value="$(arg debug)" />
  </include>
After I omitted the line "", I get another error:
[FATAL] [WallTime: 1381238959.313747] manager.launch has moved to rgbd_launch! Replace "$(find openni_launch)/launch/includes/manager.launch" with "$(find rgbd_launch)/launch/includes/manager.launch.xml". This notice will be removed in ROS Indigo
[FATAL] [WallTime: 1381238959.424237] device.launch has moved to openni_launch! Replace "$(find openni_launch)/launch/includes/device.launch" with "$(find openni_launch)/launch/includes/device.launch.xml". This notice will be removed in ROS Indigo
[FATAL] [WallTime: 1381238959.470131] processing.launch has moved to rgbd_launch! Replace "$(find openni_launch)/launch/includes/processing.launch" with "$(find rgbd_launch)/launch/includes/processing.launch.xml". This notice will be removed in ROS Indigo
================================================================================REQUIRED process [manager_deprecated-1] has died!
process has finished cleanly
log file: /home/pr2admin/.ros/log/29e33790-3011-11e3-9aea-001517ebc33d/manager_deprecated-1*.log
Initiating shutdown!
Then I followed the instruction and replace "$(find openni_launch)/launch/includes/manager.launch" with "$(find rgbd_launch)/launch/includes/manager.launch.xml".
Here's another error I got:
included file [/opt/ros/hydro/share/rgbd_launch/launch/includes/manager.launch.xml] requires the 'name' arg to be set
Okay...let's add it back again. And then I got another error:
included file [/opt/ros/hydro/share/rgbd_launch/launch/includes/manager.launch.xml] requires the 'num_worker_threads' arg to be set
Well...can anyone provide a workable launch file for running Kinect driver?
My PR2 is running on ROS Hydro. Thanks for any help~
Originally posted by Albert K on ROS Answers with karma: 301 on 2013-10-08
Comment by jdorich on 2013-10-08:
Is there a reason you are not using "openni_launch openni.launch" similar to here: https://github.com/turtlebot/turtlebot/blob/hydro-devel/turtlebot_bringup/launch/3dsensor.launch
Comment by Albert K on 2013-10-11:
Good idea! I just tested the openni.launch in openni_launch package. There are some transform errors such that the PointCloud data can't be transformed to the base_link. After checking the doc website, I'll try to set some of the parameters to make the transform work. Thanks~
Thanks to @jdorich. I've modified the launch file based on openni.launch in openni_launch package so that it can run on PR2 Hydro correctly.
In case that someone got the same problem, here is the file.
The <!--###MODIFIED###--> comment means that the following line is where I comment out or add a new line.
Originally posted by Albert K with karma: 301 on 2013-10-11
Comment by honky on 2014-05-10:
Link is dead, could you please provide any hint for solving the issue? Would be real nice. Thx.
Comment by silgon on 2014-06-14:
dead link, please send it in some link where nobody can change the info ;)
