Due to this error(import error: No module named rospkg)( Still not yet fixed)
http://answers.ros.org/question/86126/import-errorno-module-named-rospkg/?comment=87546#comment-87546
I've tried to uninstall my ROS and the reinstall it. Well after I reinstall I still face the same problem and there is another error coming out somehow ( I guess I have uninstall my ROS in right way ).
Error:
(python-yaml had already installed.0 upgraded, 0 newly installed, 0 to remove and 133 not upgraded.)
user@ubuntu:~/fuerte_workspace$ source ~/fuerte_workspace/setup.bash
  File "<stdin>", line 4, in <module>
ImportError: No module named yaml
$PYTHONPATH
/opt/ros/fuerte/lib/python2.7/dist-packages:/opt/ros/fuerte/lib/python2.7/dist-packages:/opt/ros/fuerte/lib/python2.7/dist-packages:/opt/ros/fuerte/lib/python2.7/dist-packages:
Error 2: No output from echo $ROS_PACKAGE_PATH, it simply blank one row and the back to prompt.
Originally posted by FuerteNewbie on ROS Answers with karma: 123 on 2013-10-06
Looks like you had an issue with python fixed by a reboot: http://answers.ros.org/question/86126/import-errorno-module-named-rospkg
Originally posted by tfoote with karma: 58457 on 2013-10-06
Comment by FuerteNewbie on 2013-10-06:
What am I suppose to do? I can't even get through that 'source ~/fuerte_workspace/setup.bash' right now, I can't move on..
Comment by tfoote on 2013-10-06:
You posted at the link I sent that the problem importing rospkg was fixed when you rebooted. "Bad marshal data fixed after I reboot my computer." Does that not fix your yaml import issue?
No it doesn't. I was thinking that can I append yaml into pythonpath? Something like sys.path ( I don't remember).
python-yaml should install into your system path already, next to rospkg suggesting that you have a problem with your python installation in general.
I had tried to reinstall python for several times, it doesn't seems to have any different. Any possible mistake somewhere else?
It's likely there's a problem with your envionment. You could try to clear your .bashrc. (keep a backup.) Or another easy way might be to create a new user account and try from it.
What do you mean by creating a new user account? I thought that internally the setting will still be the same? If the problem happen in python then it will not make any difference.
That's what this test is to verify. If you can import yaml from another user it is your environment. If you cannot there's a problem with your greater python installation.
