Hey Guys,
First of if the authors of Moveit! gets a chance to read this post, I just want to say thanks and congratulate them on a great piece of software which opens up lots of opportunities as researchers to work with a robot easily and effectively.
I am currently running Moveit! 0.4 alpha with ROS Groovy on Ubuntu 12.04. We had a new robot from Meka Robotics that I am trying to get Moveit! to work on. I followed the first two quick start tutorials on the Moveit!: setup assistant and rviz plugin. Both of them worked without any problems and I am able to "plan" and see the animation of either the arms, base, zlift (specific to the meka) move. However, when I came to the gazebo part, I could not get it work, primarily because as of now there is no gazebo model for the meka robot and also gazebo just would not start for some reason. I have decided to bypass the gazebo part for now and go directly to controlling the robot. Even for this I'm guessing I would need to setup the controllers.yaml and a controller_manager.launch for my robot. I was hoping I could get some help on that.
If I understand Moveit! correctly, the way it works is it plans and publishes the "plan" to some topics and I would have to write some code to subscribe to that and get it to the controllers for the robot. Please let me know if my understanding is incorrect. Is there instructions or tutorials or even examples of working code that shows how to do the entire pipeline: plan, publish to robot, execute by the robot etc and how we can customize this to our own robot? If someone can point me to the correct direction I would be very grateful.
Thanks for your time.
Originally posted by Sudarshan on ROS Answers with karma: 113 on 2013-09-29
Post score: 6
MoveIt uses a controller manager plugin to turn it's internal plans (of type moveit_msgs::RobotTrajectory) into some form of output that robots actually understand.
The most widely used plugin is the MoveItSimpleControllerManager, which is found in moveit_plugins (https://github.com/ros-planning/moveit_plugins). This plugin turns the RobotTrajectory into a call to a control_msgs/FollowJointTrajectoryAction action server. If you already have a FollowJointTrajectoryAction action server, setup pretty much consists of entering your joint names and the namespace of the action server to a controllers.yaml and loading that yaml file.
If you don't have the standard FollowJointTrajectoryAction, you will either have to implement that action in your robot drivers/controllers, or create a new plugin that publishes the non-standard topics/actions you are using.
There are several examples of controllers.yaml with the simple plugin, which are found in moveit_robots package (https://github.com/ros-planning/moveit_robots). I'm going to avoid posting those here, as copied code here is likely to eventually go out of date.
Originally posted by fergs with karma: 13902 on 2013-09-29
Post score: 6
Comment by Sudarshan on 2013-09-29:
The manufacturer's controller code lists and subscribes to some ROS topics that when published to will move the robot. I think creating a new plugin that takes the result produced by Moveit! and publishes to these topics would work. Is there any documentation on how to do this or something similar?
Comment by fergs on 2013-09-29:
Best documentation is probably to read/modify an existing plugin. The interface for the plugin is well defined by it's API, the RobotTrajectory message is also pretty well defined.
Comment by PeterMilani on 2013-09-29:
I've a similar sort of question though not specific to MoveIt! http://answers.ros.org/question/84546/implementing-realtime-controllers-with-ros_control/. So the program that interfaces to the hardware just has to present a FollowJointTrajectoryAction server to the simple CM in order to use moveit?
Generally speaking there are several levels of "standard" interface available. One of the upper layers is the ROS messages/actions themselves -- and FollowJointTrajectoryAction is a very standard one to use indeed. A layer lower would be whatever interface ros_control uses internal.
Comment by Sudarshan on 2013-09-30:
Please forgive me for the trivial question. To implement a FollowJointTrajectoryAction server I can follow the tutorial here: http://wiki.ros.org/actionlib/Tutorials? Essentially will this "action server" will set inbetween the robots controller topics and moveit's planning mechanism? Thanks!
Comment by tobiasfeil1993 on 2017-11-27:
The repository has moved and the new link is https://github.com/ros-planning/moveit/tree/kinetic-devel/moveit_plugins
If your robot is compatible with ros_control, there is a readily available implementation of a controller exposing the FollowJointTrajectory interface. It lives in the joint_trajectory_controller package.
Originally posted by Adolfo Rodriguez T with karma: 3907 on 2013-10-02
Comment by Sudarshan on 2013-10-02:
Unfortunetly, I am currently limited to running ROS Groovy on Ubuntu 12.04 and it is my understanding that ros_control is only available for ROS Hydro. If ros_control is available for ROS Groovy, I would definitely explore it.
Comment by Adolfo Rodriguez T on 2013-10-02:
There was some discussion about doing a Groovy backport, but I believe it has not been done yet. Also, it would have to be pushed forward by the interested parties, as it would not be officially supported.
Comment by Rasmus on 2013-10-04:
ros_control can easily be installed from source in groovy, see example in the gazebo tutorial here: http://gazebosim.org/wiki/Tutorials/1.9/Installing_gazebo_ros_Packages#ROS_Groovy
