Hi.
I am currently using the layered costmap found on the branch "costmap-plugins-renamed-layers" of the navigation stack repository.
I would like to use the layered costmap and add a new layer to it. If I keep the default parameters I can see a costmap with the obstacles but as soon as I put a list of plugins in the yaml file I can't see the obstacles anymore and no error message appears.
Here is my yaml file :
local_costmap:
global_frame: /map
  robot_base_frame: /base_link
  update_frequency: 1.0
  publish_frequency: 1.0
  static_map: false
  rolling_window: true
  width: 10.0
  height: 10.0
  resolution: 0.05
  plugins:
     type: "costmap_2d::FootprintLayer"
     type: "costmap_2d::ObstacleLayer"
     type: "costmap_2d::InflationLayer"
     type: "social_navigation_layers::ProxemicLayer"
     type: "simple_layers::SimpleLayer"
I tried the simple layer tutorial and this is working; when I add it to the list I can see the result in the costmap, so the problem seems to come from the Obstacle layer.
Did anyone have this problem before ?
EDIT 1 : Other yaml files
costmap_common_params.yaml
obstacle_range: 1.5
raytrace_range: 2.0
footprint: [[0.35, 0.35], [-0.35, 0.35], [-0.35, -0.35], [0.35, -0.35]]
inflation_radius: 0.55
observation_sources: laser
laser: {sensor_frame: base_laser_link, data_type: LaserScan, topic: scan, marking: true, clearing: true}
global_costmap_params.yaml
global_costmap:
  global_frame: /map
  static_map: true
  plugins:
Caroline
Originally posted by CarolineQ on ROS Answers with karma: 395 on 2013-09-25
Comment by Hendrik Wiese on 2013-09-25:
To me that sounds like a namespace problem. Can you post the other yaml files that configure your observation sources?
Ah and by the way, you have a typo in this config file (don't know if that's just a copy & paste flaw): the second line with global_frame has to be indented as well.
As I assumed, it's a namespace problem. Your observation_sources parameter is defined outside of the corresponding namespace of the layer plugin.
Change this...
to this:
obstacle_layer:
... assuming that your launch file sets the correct namespace for the load parameter of the move_base node (like in the move_base tutorial).
Generally speaking, imho this should be explicitly mentioned somewhere in the Groovy->Hydro migration tutorial for move_base and costmap_2d since I ran into the very same problem and I guess @CarolineQ and me are not the only ROS noobs who make this experience.
Originally posted by Hendrik Wiese with karma: 1145 on 2013-09-26
Comment by CarolineQ on 2013-09-26:
Thanks for this answer, it's probably the problem, I will try it as soon as possible and come back to you.
Comment by David Lu on 2013-09-26:
I concur that it should be mentioned in the tutorial. An oversight on my part. It is a wiki :)
Comment by Hendrik Wiese on 2013-09-26:
I've added some information regarding @CarolineQ's other question to the migration page in the wiki.
Thanks! Most helpful.
You're welcome. When I find some time after this weekend (gonna get married) I'll add some more.
