I'm trying to follow this tutorial: http://wiki.ros.org/pcl/Tutorials
However, I'm not sure what the CMake file needs to look like. I'm getting the following error when compiling:
Could not find a configuration file for package pcl.
Set pcl_DIR to the directory containing a CMake configuration file for pcl. The file will have one of the following names:
pclConfig.cmake
pcl-config.cmake
Originally posted by atp on ROS Answers with karma: 529 on 2013-09-20
It looks like this tutorial is outdated. In hydro, pcl is no more available as a package dependency, but now as a system dependency, meaning the default CMake mechanism described here at the end of the section has to be used.
The moveit_ros_perception package can serve as an example (pretty sure you could find others, but that one was the first that crossed my mind).
Originally posted by Stefan Kohlbrecher with karma: 24361 on 2013-09-20
Comment by atp on 2013-09-21:
That helped a lot! Thank you!
