Hello
I was wondering if its possible to get a list of all services to which a node is connected, either as a client or as a server.
Somethis similar to ros::this_node::getSubscribedTopics()
http://docs.ros.org/electric/api/roscpp/html/namespaceros_1_1this__node.html#a81620bbd1e0a3196d694c38fbd4dea8a
Also, is it possible to know which parameters a node has read.
Thanks
Miguel Oliveira
Originally posted by Miguel Riem de Oliveira on ROS Answers with karma: 254 on 2013-09-20
Comment by Miguel Riem de Oliveira on 2013-10-01:
Hi everyone
I found a workaround for this one.
I use the shell ros service list api from ros.
To make a system call and then get back the result I use ipstream library.
Perhaps it is helpfull for someone.
PS: I just did not find a way to get the client services a node is connected to ...
Hi Miguel,
You need to call getSystemState(caller_id) from the ROS XMLRPC Master API, and it returns a list of all the subscribers, publishers, and services. The Master API documentation URL: wiki.ros.org/ROS/Master_API
Thanks,
Aaron
Originally posted by unknown_entity1 with karma: 104 on 2013-10-05
Comment by Miguel Riem de Oliveira on 2013-10-22:
Thanks for the answer Aaron. I'll do that. Miguel
Comment by unknown_entity1 on 2013-10-23:
Your welcome! There are multiple deficiencies in the API related to Services. Including the inability to obtain the Service Topic Type, and the inability to request MD5 information for Topics/Services.
