Currently running the newest version of turtlebot_simultor and everything is running very well on hydro.
I'm working on a project where I'm trying to integrate POMDP with the turtlebot. I'm trying to get the simmulation working with POMDP first before moving to the actual turtlebot while I'm still testing the Policy and Model.
How can I get raw data from the kinect sensor in the simulation. I've seen the point cloud map it can create in rviz which is useful for one part of the project but I currently need a way to extract a depth value for following a target at a set distance. I'd like to write a small script that just listens to the data being output from the sensor node and passes the important data into the policy and then send the move command somehow to the turtlebot.
Eventually this will be used for a tracking and facial recognition project. The aim is to see how the turtlebot will act while following a target with uncertainty. Depth will be important for following from a certain distance (Which is the first goal) and then after that will be the bot moving to see a face that will be run through a facial recognition program. This last goal will require an image output to be scanned.
Does anyone know of a way to achieve something like this? Some form of automated control?
Thanks.
Originally posted by Alkaros on ROS Answers with karma: 103 on 2013-09-15
