Hello. I am new to ROS Running Groovy on 12.04 LTS.
i am trying to add the Rosserial for the Communication of Arduino with ROS. every thing goes fine i follow this tutorial wiki.ros.org/rosserial_arduino/Tutorials/Arduino%20IDE%20Setup.
1.i installed Arduino IDE
2.i run all these commands successfully
cd catkin_workspace/src
git clone //github.com/ros-drivers/rosserial.git
cd catkin_workspace
catkin_make
catkin_make install
source catkin_workspace/install/setup.bash
Al last when i run this Command after going into the libraries folder of sketchbook.
rosrun rosserial_arduino make_libraries.py
i get this Message]
[rospack] Error: stack/package rosserial_arduino not found
Originally posted by Neo on ROS Answers with karma: 23 on 2013-09-15
You forgot the the dot on the last command rosrun rosserial_arduino make_libraries.py . Try that. Also, your source should be source PATH_TO/catkin_workspace/install/setup.bash if in your home directory, source ~/catkin_workspace/install/setup.bash. Can you roscd into rosserial_arduino?
Originally posted by tonybaltovski with karma: 2549 on 2013-09-15
Comment by Neo on 2013-09-24:
thnaks i am now able to compile code with ros.h in arduino IDE
