I am trying to understand how PCL is integrated into ROS Hydro. I installed ROS in Ubuntu 12.04 using the ros-hydro-desktop-full package. From "rospack list" I can see that it comes with 4 PCL packages:
  1. pcl
  2. pcl_conversions
  3. pcl_msgs
  4. pcl_ros
What is the functionality of these 4 packages, especially pcl_ros and pcl? There is also a pcl-1.7 folder in my /opt/ros/hydro/share folder with some cmake config files. There is no package.xml file though. What does this folder do?
Also, I seem to have 2 copies of the pcl-1.7 libraries. I have it in /usr/lib and also in /opt/ros/hydro/lib. So it seems like I have a standalone pcl library (I am not sure how I got this) and one that is integrated with ROS. Is this going to be a problem?
Finally, and this is the biggest source of my confusion, the wiki page for hydro/migration says:
pcl is no longer packaged by the ROS community as a catkin package, so any packages which directly depend on pcl should instead use the new rosdep rules libpcl-all and libpcl-all-dev and follow the PCL developer's guidelines for using PCL in your CMake.
So, why is there a pcl package in ROS Hydro in the first place with libraries in /opt/ros/hydro/lib?
As you can see I am quite confused, any help will be greatly appreciated!
Originally posted by munnveed on ROS Answers with karma: 77 on 2013-09-11
The question was answered in the PCL Users mailing list.
http://www.pcl-users.org/How-do-I-use-PCL-from-ROS-Hydro-td4029613.html
Originally posted by munnveed with karma: 77 on 2013-09-12
Comment by aknirala on 2013-09-15:
If possible, please enumerate the exact steps needed for this. I was following the tutorial : http://wiki.ros.org/pcl/Tutorials, but was not able to run it. While creating package I needed to remove pcl dependency, then also I was not able to compile code using voxel_grid.
Comment by munnveed on 2013-09-15:
Can specify exactly what error you are getting? And are you using ROS Hydro?
Comment by ndepalma on 2013-09-24:
I'm confirming that the tutorials should be updated.
Comment by aknirala on 2013-10-12:
Hi, I was able to run it, and pointed out the changes at : http://answers.ros.org/question/90176/running-pcl-in-hydro/ kindly let me know if some correction needs to be done.
Comment by Athoesen on 2013-11-03:
Did you happen to update the tutorial or should I follow the changes on the above link you just put?
Comment by aknirala on 2013-11-03:
I have updated the tutorial (quite sometime), you can find comments in tutorial saying for hydro users kindly use... Let me know if things are fine.
