Compiling object_recognition_tabletop from source on Hydro throws lots of warning like this one:
CMake Warning at object_recognition_tabletop/src/db/CMakeLists.txt:2 (add_library):
  Cannot generate a safe runtime search path for target tabletop_db because files in some directories may conflict with libraries in implicit directories:
runtime library [libpcl_common.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_kdtree.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_octree.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_search.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_io.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_sample_consensus.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_filters.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_visualization.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_outofcore.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_features.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_segmentation.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_people.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_registration.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_recognition.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_keypoints.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_surface.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
runtime library [libpcl_tracking.so.1.7] in /usr/lib may be hidden by files in:
  /opt/ros/hydro/lib
Some of these libraries may not be found correctly.
What do I need to do to fix this?
Originally posted by bit-pirate on ROS Answers with karma: 2062 on 2013-09-05
@vincent-rabaud found out the cause. I'll just quote him:
You still have the ros-hydro-pcl package. You should remove it since that is now a system dependecy (hence in /usr/lib). It is not even part of the Hydro distribution anymore (as of 2 weeks ago)
Originally posted by bit-pirate with karma: 2062 on 2013-09-06
