Hello every one. I want to use Arduino uno to just send a helloworld to ros. I am using groovy. from the and follow the instruction here that is in rosserial tutorials
I followed ROSBUILD, after "rosmake rosserial_arduino" I can not run "roscd rosserial_arduino/libraries" because this location does not exist. after that I found the rosserial_arduino in /opt/ros/groovy/share/ and in this folder I found ros_lib. So I added ros_lib to my arduino IDE libraries.
I want to write codes in my IDE, just after adding #include<ros.h> I see this error:
In file included from sketch_sep05a.ino:1: /home/mohammad/Desktop/Arduino/arduino-1.5.3/libraries/ros_lib/ros.h:38:29: error: ros/node_handle.h: No such file or directory In file included from sketch_sep05a.ino:1: /home/mohammad/Desktop/Arduino/arduino-1.5.3/libraries/ros_lib/ros.h:49: error: expected initializer before ‘<’ token
I think that header files like ros.h have problems. what should I do? What is the best way to use rosserial and rosserial_arduino in groovy? thanks a lot!!!
Originally posted by narenji on ROS Answers with karma: 11 on 2013-09-04
If you checked out the groovy-devel branch from the rosserial github project, then you need to build with catkin, not rosmake. You will also likely have to do the "install" step, because rosserial_arduino actually gets a number of it's roslib files from rosserial_client during the install step.
Originally posted by fergs with karma: 13902 on 2013-09-29
I had the same problem because they say in the ROS Wiki to copy the ros_lib to Sketchbook folder.
when i copied the ros_lib to /usr/share/arduino/libraries/
it worked fine.
Now i can compile any code with ros.h or any other RSO code
Originally posted by Neo with karma: 23 on 2013-09-24
