I have a single publisher that publishes messages at high frequency (1800 Hz), and a subscriber in another node. I realized that the messages are not always processed sequentially. I verified this by doing the following: in the callback function, I output a warning every time the seq number of the processed message is lower than the seq number of the message processed in the previous call of the callback.
My question: is there a way to force a subscriber to process the incoming messages exactly in the order of the seq numbers in their header? (up to now I thought this would be the case by default with a single subscriber/publisher system, but apparently it isn't...)
Any help is greatly appreciated!
Originally posted by philippp625 on ROS Answers with karma: 21 on 2013-08-17
Comment by philippp625 on 2013-08-19:
I just realized that my problem only exists if I use a tf::MessageFilter when subscribing. Nevertheless, I don't understand why the messages are not processed in the order of their time stamps, since they all have the same frame_id, so the transforms should be available for older messages first.
The message filter is specifically designed to cache and potentially return messages when they're ready and doesn't keep the order internally. You could write a specialization which would return them only in the incoming order.
Originally posted by tfoote with karma: 58457 on 2017-12-05
