Recently switched to groovy and rostopic doesn't seem to be able to handle arrays anymore. Does anyone know why?
Example for me, from a simple topic with a list of doubles: rostopic echo /robot/joint_states/position[1]
Results in:
Traceback (most recent call last):   File "/opt/ros/groovy/bin/rostopic", line 35, in <module>
    rostopic.rostopicmain()   File "/opt/ros/groovy/lib/python2.7/dist-packages/rostopic/__init__.py", line 1666, in rostopicmain
    _rostopic_cmd_echo(argv)   File "/opt/ros/groovy/lib/python2.7/dist-packages/rostopic/__init__.py", line 1026, in _rostopic_cmd_echo
    _rostopic_echo(topic, callback_echo, bag_file=options.bag)   File "/opt/ros/groovy/lib/python2.7/dist-packages/rostopic/__init__.py", line 692, in _rostopic_echo
    index = submsg_class.__slots__.index(field) ValueError: 'position[1]' is not in list`
Originally posted by mattadc on ROS Answers with karma: 3 on 2013-08-14
Comment by SL Remy on 2013-08-15:
Are you sure that that topic is correct? Can you update this question with the results of rostopic info /robot/joint_states ?
It looks like a regression of https://github.com/ros/ros_comm/issues/242
It is fixed in https://github.com/ros/ros_comm/commit/2af3d693645f084086ef0a5c50f9b666ea0fc1fd and will be available with the next ros_comm release (1.9.48).
Originally posted by Dirk Thomas with karma: 16276 on 2013-08-15
Comment by mattadc on 2013-08-16:
Yes, this fixed the problem. Thank!
