OS: Ubuntu 12.04 LTS Processor: Intel® Core™2 Duo CPU E6550 @ 2.33GHz × 2 ROS Groovy
For the driver stack: http://ros.org/wiki/xsens_driver
as mentioned here: http://answers.ros.org/question/56635/xsens-error-comunicating-with-ubuntu-1204/ the IMU device can not mapped in a node because of the impossibility to read the USB device.
For the other driver stack: http://www.ros.org/wiki/lse_xsens_mti when I try to make the building I got this error however I already downloaded and built "gps_common":
mkdir -p bin cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=/opt/ros/groovy/share/ros/core/rosbuild/rostoolchain.cmake .. [rosbuild] Building package lse_xsens_mti [rosbuild] Cached build flags older than manifests; calling rospack to get flags Failed to invoke /opt/ros/groovy/bin/rospack cflags-only-I;--deps-only lse_xsens_mti Package gps_common was not found in the pkg-config search path. Perhaps you should add the directory containing `gps_common.pc' to the PKG_CONFIG_PATH environment variable No package 'gps_common' found [rospack] Error: python function 'rosdep2.rospack.call_pkg_config' could not call 'pkg-config --cflags-only-I gps_common' without errors
Does somebody has an idea how to make an IMU working on ROS in Ubuntu 12.04? Thank you very much,
Claudio
Originally posted by ClaudioS on ROS Answers with karma: 21 on 2013-08-12
Comment by aswin on 2014-05-12:
Make sure gps_common is in your path. Install the correct version catkin/rosbuild and build it.
This seems to highly depend on the Xsens that you have. According to the question you linked the newer versions need an updated driver/interface from xsens for linux. The older ones should work with the currently available drivers.
Originally posted by dornhege with karma: 31395 on 2013-08-12
