So I am trying to run roboearth_stack on ros-groovy, ubuntu 12.04 lts machine without much success. Though I have tried it earlier on fuerte and it works perfectly, I am not too sure if its possible to run it on groovy. Has anyone tried it yet?
This is the output of rosmake roboearth:
[rosmake-1] Starting >>> opencv2 [ make ] [rosmake-1] Finished <<< opencv2 ROS_NOBUILD in package opencv2 No Makefile in package opencv2 [rosmake-1] Starting >>> cv_bridge [ make ] [rosmake-1] Finished <<< cv_bridge ROS_NOBUILD in package cv_bridge No Makefile in package cv_bridge [rosmake-1] Starting >>> class_loader [ make ] [rosmake-1] Finished <<< class_loader ROS_NOBUILD in package class_loader No Makefile in package class_loader [rosmake-1] Starting >>> pluginlib [ make ] [rosmake-1] Finished <<< pluginlib ROS_NOBUILD in package pluginlib No Makefile in package pluginlib [rosmake-1] Starting >>> image_transport [ make ] [rosmake-1] Finished <<< image_transport ROS_NOBUILD in package image_transport No Makefile in package image_transport [rosmake-1] Starting >>> visualization_msgs [ make ] [rosmake-1] Finished <<< visualization_msgs ROS_NOBUILD in package visualization_msgs No Makefile in package visualization_msgs [rosmake-1] Starting >>> resource_retriever [ make ] [rosmake-1] Finished <<< resource_retriever ROS_NOBUILD in package resource_retriever No Makefile in package resource_retriever [rosmake-1] Starting >>> ar_pose [ make ] [rosmake-2] Finished <<< rosprolog [PASS] [ 3.21 seconds ] [rosmake-2] Starting >>> semweb [ make ] [rosmake-3] Finished <<< tf_prolog [PASS] [ 3.29 seconds ] [rosmake-3] Starting >>> ias_prolog_addons [ make ] [rosmake-0] Finished <<< re_msgs [PASS] [ 6.22 seconds ] [rosmake-0] Starting >>> re_srvs [ make ] [rosmake-2] Finished <<< semweb [PASS] [ 3.30 seconds ] [rosmake-2] Starting >>> knowrob_common [ make ] [rosmake-3] Finished <<< ias_prolog_addons [PASS] [ 3.28 seconds ] [rosmake-3] Starting >>> re_2dmap_extractor [ make ] [rosmake-1] Finished <<< ar_pose [PASS] [ 4.68 seconds ] [rosmake-1] Starting >>> re_vision [ make ] [ rosmake ] Last 40 lines_srvs: 9.1 sec ] [ knowrob_common: 8.8 sec ] [ re_2dmap_extractor: 8.7 sec ] [... [ 4 Active 64/93 Complete ] {------------------------------------------------------------------------------- [ 51%] Built target createPlyPoints make[3]: Entering directory /home/gautam/ros/stacks/roboearth/re_vision/build' make[3]: Leaving directory /home/gautam/ros/stacks/roboearth/re_vision/build' [ 53%] Built target createPointCloudModel make[3]: Entering directory /home/gautam/ros/stacks/roboearth/re_vision/build' make[3]: Leaving directory /home/gautam/ros/stacks/roboearth/re_vision/build' [ 56%] Built target extractOutlineFromImages make[3]: Entering directory /home/gautam/ros/stacks/roboearth/re_vision/build' make[3]: Leaving directory /home/gautam/ros/stacks/roboearth/re_vision/build' [ 59%] Built target extractSurf make[3]: Entering directory /home/gautam/ros/stacks/roboearth/re_vision/build' make[3]: Leaving directory /home/gautam/ros/stacks/roboearth/re_vision/build' [ 62%] Built target removeBackgroundPoints In file included from /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorClass.h:39:0, from /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorClass.cpp:37: /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorProvider.h:42:32: fatal error: cv_bridge/CvBridge.h: No such file or directory compilation terminated. [ 64%] Building CXX object CMakeFiles/ObjectDetectorFunctions.dir/src/SurfPlanarDetector.cpp.o /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorProvider.cpp:39:32: fatal error: cv_bridge/CvBridge.h: No such file or directory compilation terminated. In file included from /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorMethod.h:41:0, from /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorMethod.cpp:36: /home/gautam/ros/stacks/roboearth/re_vision/src/VisualizationManager.h:38:32: fatal error: cv_bridge/CvBridge.h: No such file or directory compilation terminated. In file included from /home/gautam/ros/stacks/roboearth/re_vision/src/ObjectDetectorMethod.h:41:0, from /home/gautam/ros/stacks/roboearth/re_vision/src/SurfPlanarDetector.h:37, from /home/gautam/ros/stacks/roboearth/re_vision/src/SurfPlanarDetector.cpp:33: /home/gautam/ros/stacks/roboearth/re_vision/src/VisualizationManager.h:38:32: fatal error: cv_bridge/CvBridge.h: No such file or directory compilation terminated. make[3]: *** [CMakeFiles/ObjectDetectorFunctions.dir/src/ObjectDetectorClass.cpp.o] Error 1 make[3]: *** Waiting for unfinished jobs.... make[3]: *** [CMakeFiles/ObjectDetectorFunctions.dir/src/ObjectDetectorProvider.cpp.o] Error 1 make[3]: *** [CMakeFiles/ObjectDetectorFunctions.dir/src/ObjectDetectorMethod.cpp.o] Error 1 make[3]: *** [CMakeFiles/ObjectDetectorFunctions.dir/src/SurfPlanarDetector.cpp.o] Error 1 make[3]: Leaving directory /home/gautam/ros/stacks/roboearth/re_vision/build' make[2]: *** [CMakeFiles/ObjectDetectorFunctions.dir/all] Error 2 make[2]: Leaving directory /home/gautam/ros/stacks/roboearth/re_vision/build' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/gautam/ros/stacks/roboearth/re_vision/build'
[ rosmake ] Output from build of package re_vision written to: [ rosmake ] /home/gautam/.ros/rosmake/rosmake_output-20130809-172211/re_vision/build_output.log [rosmake-1] Finished <<< re_vision [FAIL] [ 8.18 seconds ]
[ rosmake ] Halting due to failure in package re_vision. [ rosmake ] Waiting for other threads to complete.
[rosmake-0] Finished <<< re_srvs [PASS] [ 14.24 seconds ]
[rosmake-2] Finished <<< knowrob_common [PASS] [ 17.12 seconds ]
[rosmake-3] Finished <<< re_2dmap_extractor [PASS] [ 25.48 seconds ]
[ rosmake ] Results:
[ rosmake ] Built 68 packages with 1 failures.
[ rosmake ] Summary output to directory
I my opinion the problem is with roboearth packages as they mainly support ros- fuerte, so my question is, will these packages run in groovy?if yes, how? and If not, is there any other way to run roboearth in ros-groovy?
I would be happy to provide any other detail regarding this issue.
Thank you.
Originally posted by gautam2410 on ROS Answers with karma: 71 on 2013-08-08
There are a number of different issues involved in running the roboearth_stack package on ROS Groovy. I wrote down the solution to most of them here, and even though it might not be complete, it should address quite a lot of the known problems.
Originally posted by micpalmia with karma: 58 on 2013-09-03
Comment by gautam2410 on 2013-09-03:
Thank you for your reply and for addressing the problem of roboearth with groovy. I will try to follow your solution and then discuss further.
Comment by rmb209 on 2014-04-09:
Just wondering whether you managed to get roboearth stack to work with groovy?
Comment by Michele Palmia on 2014-04-11:
I linked my solution in the response, the procedure is a bit messy but it works.
