I'd like to have a python module globally available across all nodes in a catkin workspace. It contains functions that I don't want to repeat in every module I need them. They are pure Python modules. I'd like to do something like this:
#!/usr/bin/env python
# mymodule.py
def myFunction(a):
  # just an example
  something = a * 2
  return something
# End of mymodule.py
And in my ROS Python scripts I'd like to be able to import that module like...
import roslib...
import mymodule
def someotherfunc():
  b = mymodule.myFunction(10)
if __name__ ==...
It shall be available in my whole catkin workspace. Where do I have to put it?
Thanks a lot!
Originally posted by Hendrik Wiese on ROS Answers with karma: 1145 on 2013-08-02
I think this tutorial covers what you would like to do:
summary:
1. Create setup.py in your package root directory with these contents (where <python_mod> is replaced by the name of your python module, typically the same name as your catkin package)
## ! DO NOT MANUALLY INVOKE THIS setup.py, USE CATKIN INSTEAD
from distutils.core import setup
from catkin_pkg.python_setup import generate_distutils_setup
# fetch values from package.xml
setup_args = generate_distutils_setup(
    packages=['<python_mod>'],
    package_dir={'': 'src'},
    requires=['std_msgs', 'rospy'])
setup(**setup_args)
2. Add the following line to your CMakeLists.txt
catkin_python_setup()
3. Create a directory for your python scripts (if you have any python executables)
mkdir <pkg_root>/scripts
4. Create a directory for your python modules
mkdir <pkg_root>/src/<python_mod>/
5. Add an empty __init__.py to your python module directory
touch <pkg_root>/src/<python_mod>/__init__.py
6. create your python mod
touch <pkg_root>/src/<python_mod>/mod1.py
You should now be able to import this module as
import python_mod.mod1
Hope that helps!
Reference the tutorial for details.
Originally posted by dPackard with karma: 115 on 2013-08-02
Comment by Hendrik Wiese on 2013-08-06:
Yeah, works like a charm! Thanks a lot! :-)
