Ubuntu 12.04 groovy
I have installed the rosserial by using the instructions at github.com/ros-drivers/roserial and followed the catkin instructions
cd catkin_ws catkin make catkin make install source ~/catkin_ws/install/setup.bash cd /home/charlie/sketchbook/libraries rosrun rosserial_arduino make_libraries.py
everything seems to work OK up to this point, then I get the following statement
"make_libraries.py generates the Arduino rosserial library files. It requires the location of your Arduino sketchbook/libraries folder"
Arduino is installed on the desktop.
Any ideas ?
Originally posted by CharlieD on ROS Answers with karma: 15 on 2013-08-01
The command to make the libraries is rosrun rosserial_arduino make_libraries.py . The period is need to specify your current directory.
Originally posted by tonybaltovski with karma: 2549 on 2013-08-01
Post score: 4
Comment by CharlieD on 2013-08-04:
That was it, it worked perfectly, Thanks for your help
