I am using ros_arduino_bridge to operate an arduino-based robot and it works well both for odometry and motor driving. However, I want to add a gyro to enable better calibration and also to then have the functionality of a turtlebot. Then it is easy to add additional sensors such as a kinect.
I know that I could write stand-alone routines to feed the gyro data directly, but it is a hurdle to get a sufficient understanding of nav msgs and figure out the details of how to correctly publish that data. Since ros_arduino_bridge does such a nice job with wheel odometry, I am hoping that there is a way to incorporate gyro data.
Originally posted by dan on ROS Answers with karma: 875 on 2013-07-31
Hi @dan - it shouldn't be that hard to add gyro support but (as the author of the ros_arduino_bridge package), I don't have the time to do it myself right now. Anyone else is welcome to fork the repo and give it whirl. A good place to start might be the Turtlebot code.
FWIW, I do not use a gyro on Pi Robot and I am able to do SLAM and AMCL just fine using wheel odometry alone, albeit with a laser scanner. If I remember correctly, the original reason to put a gyro on the Create-based TurtleBot was because the wheel odometry was rather unreliable, especially when turning.
Originally posted by Pi Robot with karma: 4046 on 2013-08-02
Comment by dan on 2013-08-02:
Thanks for the timely response. I have found that a gyro makes a huge improvement for turning accuracy over wheel odometry, so would really like to incorporate that data. I tried to add gyro support in the way that Turtlebot does, but got bogged down with the details of /imu/data and imu/raw.
I spent many hours going through the nav tutorials and trying to pick apart the Turtlebot code but ultimately failed. I bought the book ROS by Example, which is excellent, but was disappointed that even that book does not cover using a gyro.
I see from ros.answers that a lot of people have the same problem trying to get gyro data into a non-create-based version of Turtlebot.
I could publish the gyro data as the theta component of /odom, that seems straightforward, but I don't know if that will allow me access to the good nav features of Turtlebot, since it means I have to use the "no gyro present" option. Do you think that would work??
These were actually just one comment, but had to be broken up due to character limits.
