I am trying to access the bumps wheeldrops sensor from the Turtlebot sensor_state topic. However, the bump sensor is never activated. In fact, if I execute rostopic echo /turtlebot_node/sensor_state, all the sensor_state values are permanently set to 0. In addition, I noticed that the /odom Twist parameter remains 0 even when the robot is moving. Here is my launch file:
<launch>
    <arg name="use_sim_time" default="true"/>
    <arg name="gui" default="true"/>
    <!-- start gazebo with an empty plane -->
    <param name="/use_sim_time" value="true" />
    <node name="gazebo" pkg="gazebo" type="gazebo" args="-u $(find turtlebot_gazebo)/worlds/1box.world" respawn="false" output="screen"/>
    <include file="$(find turtlebot_gazebo)/launch/robot.launch"/>
    <!-- start gui -->
    <group if="$(arg gui)">
        <node name="gazebo_gui" pkg="gazebo" type="gui" respawn="false" output="screen"/>
    </group>
</launch>
And here is the simple program that is running as a node:
#include <ros/ros.h>
#include <turtlebot_node/TurtlebotSensorState.h>
#include <geometry_msgs/Twist.h>
#include <ros/rate.h>
#include <iostream>
#include <stdio.h>
using namespace std;
uint8_t bumper;
void bumperCallback(const turtlebot_node::TurtlebotSensorState::ConstPtr& msg);
int main (int argc, char** argv){
    ros::Time start, end;
    ros::init(argc, argv, "bumper");
    ros::NodeHandle nodeH;
    ros::Rate loop_rate(10); //10 Hz.
    geometry_msgs::Twist twist;
    //Bumper subscriber.
    ros::Subscriber bumperSub = nodeH.subscribe<turtlebot_node::TurtlebotSensorState>("/turtlebot_node/sensor_state", 1000, bumperCallback);
    //Moving.
    ros::Publisher movingPub = nodeH.advertise<geometry_msgs::Twist>("cmd_vel", 1000);
    //Twist set to navigate forward.
    double forwardSpeed = 0.15;
    twist.linear.x = forwardSpeed;
    twist.linear.y = 0;
    twist.linear.z = 0;
    twist.angular.x = 0;
    twist.angular.y = 0;
    twist.angular.z = 0;
    start = ros::Time::now(); //Time when the robot starts moving.
    while(ros::ok){
        if(bumper != 0){
            end = ros::Time::now(); //Time when robot bumped into a wall.
            ROS_INFO("BOOM OUCH");
        else{ //Go forward until the robot bumps into a wall.
            ROS_INFO("Going forward");
            movingPub.publish(twist);
        loop_rate.sleep();
        ros::spinOnce();
    return 0;
//Fetch the sensor state containing the bumper state.
void bumperCallback(const turtlebot_node::TurtlebotSensorState::ConstPtr& msg){
    bumper = msg->bumps_wheeldrops;
    ROS_INFO("Bumper is %d .", bumper);
I verified that Gazebo is indeed publishing on "/turtlebot_node/sensor_state" and that my own node is subscribed to it. How can I solve this problem? I've researched similar topics, but I don't see anything wrong with my files based on these.
Note that the following warning is being reported by Gazebo, but I think it's irrelevant:
Warning [RaySensor.cc:206] ranges not constructed yet (zero sized)
[Edit] I just noticed these additional errors. I had not seen them before because the RaySensor warning is being displayed thousands of times. Gazebo seems to be running fine, though...
Warning [parser.cc:348] Gazebo SDF has no gazebo element
Warning [parser.cc:291] DEPRECATED GAZEBO MODEL FILE
On July 1st, 2012, this formate will no longer by supported
Convert your files using the gzsdf command line tool
You have been warned!
Error [ColladaLoader.cc:1392] No Opaque set
[ INFO] [1375303568.841199057]: imu plugin missing <serviceName>, defaults to /default_imu
[ INFO] [1375303568.842760080]: imu plugin missing <xyzOffset>, defaults to 0s
[ INFO] [1375303568.844350786]: imu plugin missing <rpyOffset>, defaults to 0s
Dbg plugin model name: turtlebot
[ERROR] [1375303568.887177379]: Unable to find sensor[wall_sensor]
spawn status:  SpawnModel: successfully spawned model
[FATAL] [1375303568.951720905, 0.001000000]: ASSERTION FAILED
    file = /opt/ros/fuerte/include/ros/publisher.h
    line = 102
    cond = false
    message =
[FATAL] [1375303568.954664227, 0.001000000]: Call to publish() on an invalid Publisher
[FATAL] [1375303568.955377726, 0.001000000]:
Unhandled exception in thread started by
sys.excepthook is missing
lost sys.stderr
[Edit2] I tried my program with a real Turtlebot and it works; the sensor_state parameters are being updated. Now why wouldn't it work with Gazebo?
Originally posted by Zayin on ROS Answers with karma: 343 on 2013-07-31
Comment by jorge on 2013-08-22:
are u using hydro or groovy? If in hydro, there's still a lot of work to do: https://github.com/turtlebot/turtlebot_create_desktop/issues/3
Comment by Zayin on 2013-08-26:
I'm sorry I forgot to mention it. I'm using Fuerte,
Comment by Zayin on 2013-08-28:
Oh, I see, thanks! I shouldn't have assumed Gazebo was fully implemented.
For the sensor_state 0s, I don't know; probably you will need to dig in the code to see if there's a problem or it's just not implemented. For the 0 velocity on odometry, I took a fast look at the code and it's just not implemented.
Originally posted by jorge with karma: 2284 on 2013-08-27
