Hello,
I'm having few SMACH states in different files and would like to use TF in some of them. There will be probably even some concurrent states so, I created helper class tf_utils (helper_methods.py) with TF listener protected by mutex. It's initialized like this:
_tfl = None def get_tfl(): return _tfl def init_tfl(): global _tfl if _tfl is None: _tfl = tf_utils()
Class tf_utils looks like this:
class tf_utils(): def __init__(self,timeout=None): if timeout is None: timeout = rospy.Duration(5) self.timeout = timeout self.tfl = TransformListener() self.mutex = threading.Lock() def waitForTransform(self,f1,f2,time): ret = True self.mutex.acquire() try: self.tfl.waitForTransform(f1,f2,time,self.timeout) except tf.Exception: ret = False self.mutex.release() return ret
etc...
In main file, I initialize node (rospy.init_node) and tf_utils (helper_methods.init_tfl()). Then for instance frameExists method works fine while with waitForTransform I'm getting this:
terminate called after throwing an instance of 'ros::TimeNotInitializedException' what(): Cannot use ros::Time::now() before the first NodeHandle has been created or ros::start() has been called. If this is a standalone app or test that just uses ros::Time and does not communicate over ROS, you may also call ros::Time::init()
Situation is same for both wall time or simulated time.
What's wrong? Or is there any other approach how to use one transform listener in more python modules / SMACH states?
UPDATE:
This is how I initialize my stuff. First I initialize rospy and then (in main) my tf listener.
if __name__ == '__main__': rospy.init_node('rt_decision_making') try: main() except rospy.ROSInterruptException: print "program interrupted before completion"
and...
def main(): helper_methods.init_tfl() tfl = helper_methods.get_tfl()
UPDATE2:
I ended up with the most simple python script:
#!/usr/bin/env python import roslib; roslib.load_manifest('rt_decision_making') import rospy import tf from tf import TransformListener def main(): rospy.init_node('rt_decision_making') rospy.sleep(2) tfl = TransformListener() rospy.sleep(2) tfl.waitForTransform("base_link", "velodyne", rospy.Time.now(), rospy.Duration(1)) if __name__ == '__main__': try: main() except rospy.ROSInterruptException: print "program interrupted before completion"
...which works in Groovy but not in Hydro which I'm currently working with.
Originally posted by ZdenekM on ROS Answers with karma: 704 on 2013-07-31
