Hello Every body , I am new in Ros and Python I would like to use joint_angles topic to control only on joint of NAO lets say HeadYaw Id it possible to let me know the procedure?
I was running the following command but it does not work :
rostopic pub /joint_angles nao_msgs/JointAnglesWithSpeed '{seq: 1, stamp: now, frame_id: Head}' '['[HeadYaw,HeadPitch]',[1,-1],2.0,0]'
Originally posted by Mohsen 2013 on ROS Answers with karma: 3 on 2013-07-26
Comment by Miguel S. on 2013-07-26:
Could you change the title to something more descriptive? Eg. 'Sending messages to nao_controller from rostopic_pub'. It'll make it easier for future users to find your question :)
There are two issues with your command:
  • On ROS groovy the line is not being accepted, if you flatten your arrays and add -- for the negative numbers it works
  • The relative speed must be a value between 0 and 1
So if you type something like this...
rostopic pub /joint_angles nao_msgs/JointAnglesWithSpeed -- '[ 1, now, Head]' '[HeadYaw,HeadPitch]' '[1,-1]'  1.0  0
... it should work (at least on groovy with nao_controller up and running)
Originally posted by Miguel S. with karma: 1114 on 2013-07-26
Comment by Mohsen 2013 on 2013-07-26:
Thanks alot :)
