Power Block Designing noob here.
I have a beaglebone 2x XbeePro(s) and another 500mAh device connected to the board i am building a PCB Around.
I need some advice on weather to use Linear Voltage Regulation vs Switching mode regulation.
Secondly if i am using linear voltage regulation setup do I need multiple regulators for the different devices?
My plan is to use A 2S 1000mAh Battery -> Fuse -> 2x 1.5A LM1084's in parallel output feed to the beaglebone and a LM3940 for both the XBees. Or its better to have each XBee on its on LM3940 drawing power from a seperate LM1084?
Linear Regulators tend to get hot on full load, hows the performance of Switching mode regulators ?
A linear regulator has a major drawback: it dissipates the power it doesn't deliver. Using the well-known 7805, the output voltage is 5V, your input shall be at least 7V to allow a good regulation (2V dropout voltage), if your load requires 1A, your 7805 dissipates 1A * 2V = 2W. This makes your Linear regulator hot. The best efficiency you may expect from a 7805 is 70% (and, to the best of my knowledge, a linear regulator doesn't exceed 80%).
Switching regulators are non linear. For a switching regulator, 80% is a poor efficiency (but sometimes acceptable for very cheap designs), power efficiency is usually around 90% under full charge, and may come up to 99% when large amounts of energy are involved, with an expensive design. For little loads, efficiency may drop to 60%, due to the power consumption of the regulator itself.
So, in my opinion, you should use switching regulator, for a better power efficiency and lower heat dissipation. If you need a single voltage, try to use only one regulator: it's cheaper, and avoid the little load situation. If you want to design a low power application, you'll probably have to choose a more sophisticated design, but it's probably not the case, as you use a beaglebone, which prevents you to manage each processor power supply independently.
  • $\begingroup$ Does it make sense to use the [TPS652510](www.ti.com/lit/ds/symlink/tps652510.pdf) for my application ? or maybe a dual output switching regulator? I need the PCB Footprint to be of a bare minimum. $\endgroup$ Jan 7, 2015 at 14:43
  • $\begingroup$ Or a LTC3633A-3 This Choice is confusing. $\endgroup$ Jan 7, 2015 at 16:00
