Dear Reader,
I have been trying to work through the tutorials URDF tutorials online and have had a problem with Rviz, It looks nothing like the [tutorial's example](http:// www.ros.org/wiki/urdf/Tutorials/Building%20a%20Visual%20Robot%20Model%20with%20URDF%20from%20Scratch) and the are a few errors.
Screenshot http://s21.postimg.org/41642i6l3/URDF_example.jpg
Any suggestions as to how to fix this would be greatly appreciated.
Thanks In Advance
Originally posted by VeryNewToROS on ROS Answers with karma: 3 on 2013-07-19
Try to set the fixed frame to /base_link or /world if it exists. Currently it is set to /map which does not exist.
As David Lu wrote in his comment expand the Global Options and double click on /map next to Fixed Frame. There you have to select /base_link. There should be no problem with the VM. The /map frame is the default for rviz, at least for me.
Originally posted by BennyRe with karma: 2949 on 2013-07-19
