When I write this command on terminal: rosrun rosserial_python serial_node.py /dev/ttyUSB0 but I change my port from USB0 to ACM0 as I work on ACM0
it appears to me that: [INFO] [WallTime: 1374151755.600608] ROS Serial Python Node [INFO] [WallTime: 1374151755.601022] Connecting to /dev/ttyACM0 at 57600 baud [ERROR] [WallTime: 1374151755.603582] Error opening serial: could not open port /dev/ttyACM0: [Errno 2] No such file or directory: '/dev/ttyACM0'
and I rum roscore in a new terminal
I am on groovy
Originally posted by ahmed.shamroukh on ROS Answers with karma: 1 on 2013-07-18
Your serial port doesn't exist. Are you sure your arduino is plugged in?
ls /dev/ttyACM* and ls /dev/ttyUSB* may help you find it.
Originally posted by ahendrix with karma: 47576 on 2013-07-18
Comment by ahmed.shamroukh on 2013-07-19:
I did what you told me but I have a new error: [INFO] [WallTime: 1374246906.900536] ROS Serial Python Node [INFO] [WallTime: 1374246906.901156] Connecting to /dev/ttyACM0 at 57600 baud [INFO] [WallTime: 1374246909.946657] Failed Packet Flags [ERROR] [WallTime: 1374246924.016878] Lost sync with d
