Hi
I was wondering if anyone can point me to ros package which can compute position from IMU.
I guess by integrating the linear acceleration, one could get that, but wanted to know if there is a package for that.
If not, could you tell how to efficiently write a program for that
Thanks
Originally posted by sai on ROS Answers with karma: 1935 on 2013-07-09
Comment by dornhege on 2013-07-09:
Are you sure, you want to do that? Unless you spent a lot of money on the IMU the results are probably very noisy.
Comment by sai on 2013-07-09:
I would like to give it as one of the input to Extended Kalman Filter(robot_pose_ekf pkg) along with other sources of odometry. Unfortunately, robot_pose_ekf pkg only takes 3D orientation from IMU, So I was wondering if its possible to use 3D position too..
Strongly seconding @dornhege's comment.
The kalman filter is already doing the integration on the accelerations provided by the IMU, and using that to update its state estimate, so you're not going to get any additional accuracy by trying to spoof your own position estimates from the same data and feeding them to the ekf.
In order to improve your state estimation, I'd recommend doing a little reading on how kalman filters work (my favorite introductory explanation was in Probabilistic Robotics, I can't recommend a freely-available one off the top of my head), and then making sure that you have the right covariances for all of its inputs. If you want to improve it beyond that, you'll need to invest in better/different sensors.
Originally posted by lindzey with karma: 1780 on 2013-07-09
