I'm trying to install ROS Groovy on Fedora 19, following the instructions at wiki/groovy/Installation/Fedora. However, running the line
$ rosdep install --from-paths src --ignore-src --rosdistro groovy -y
results in the following error:
ERROR: the following packages/stacks could not have their rosdep keys resolved to system dependencies: pcl: No definition of [libusb-1.0-dev] for OS version [schrödinger’s]
locate libusb- gives:
/usr/lib/libusb-0.1.so.4 /usr/lib/libusb-0.1.so.4.4.4 /usr/lib/libusb-1.0.so.0 /usr/lib/libusb-1.0.so.0.1.0 /usr/lib64/libusb-0.1.so.4 /usr/lib64/libusb-0.1.so.4.4.4 /usr/lib64/libusb-1.0.so.0 /usr/lib64/libusb-1.0.so.0.1.0
The problem was how to get the letter 'ö' readable in the yaml file because rosdep resolve is giving this error: ERROR: No definition of [libusb-1.0-dev] for OS version [schrödinger’s]. I solved this by changing the OS name in /etc/system-release to schrodinger and then editing the yaml file.
Originally posted by atp on ROS Answers with karma: 529 on 2013-07-08
You need to add rosdep rules for Fedora 19. It's correctly detecting the OS correctly but the latest definition for libusb-1.0 is for spherical. https://github.com/ros/rosdistro/blob/master/rosdep/base.yaml
How to submit changes is documented here: http://ros.org/doc/independent/api/rosdep/html/contributing_rules.html
Originally posted by tfoote with karma: 58457 on 2013-07-09
Comment by tfoote on 2013-07-23:
You say that this doesn't work for you. What did you do to try it? What errors did you get?
Comment by atp on 2013-07-23:
see above. basically, how can I get the 'ö' readable in the yaml file?
Comment by cottsay on 2014-05-10:
For the record, this is fixed in the latest release of rospkg: https://github.com/ros-infrastructure/rospkg/pull/54
