I have the latest beta version of hydro installed on Ubuntu 13.04 and encountered this error when going through the urdf_tutorials:
ERROR: cannot launch node of type [joint_state_publisher/joint_state_publisher]: can't locate node [joint_state_publisher] in package [joint_state_publisher]
I have installed joint_state_publisher, and checked again:
$ rosdep install joint_state_publisher
#All required rosdeps installed successfully
$ rosrun joint_state_publisher joint_state_publisher
[rosrun] Couldn't find executable named joint_state_publisher below /opt/ros/hydro/share/joint_state_publisher
[rosrun] Found the following, but they're either not files,
[rosrun] or not executable:
[rosrun]   /opt/ros/hydro/share/joint_state_publisher
There is a folder in share for joint_state_publisher, but no executable code:
$ ls /opt/ros/hydro/share/joint_state_publisher/
cmake  package.xml
There is nothing in lib or include
$ ls /opt/ros/hydro/lib | grep joint_state_publisher
$ ls /opt/ros/hydro/include/ | grep joint_state_publisher
I'm not sure if this is where I should be publishing problems with pre-releases, so please direct me to the correct forum.
Brent
Originally posted by Brent Bailey on ROS Answers with karma: 51 on 2013-07-06
This is a good place to report Hydro problems.
It's possible that joint_state_publisher was converted to catkin, but is not installing its files correctly.
Originally posted by joq with karma: 25443 on 2013-07-07
Comment by jdom1824 on 2019-02-13:
I have the same problem but in kinetics, could you correct it?
Comment by ixtiyoruz on 2020-02-16:
I also have the problem, is there any solution?
