Hi, everything was OK before I did update. After update of ROS packages the ROS Groovy not work or give me the following message:
[move_monsun] is not a package or launch file name when I use the lanch file
roslaunch move_monsun move_monsun.launch
<launch>
    <group ns="monsun">
      <node pkg="move_monsun" name="PID_Move" type="move_monsun_node" output="screen">
    <param name="k_p" value="1.0" type="double"/>
    <param name="k_i" value="0.0" />
    <param name="k_d" value="0.0" />
    <param name="k_pl" value="1.0" type="double"/>
    <param name="k_il" value="0.0" />
    <param name="k_dl" value="0.0" />
    <param name="i_max" value="0.0" />
    <param name="output_min" value="-60.0" />
    <param name="output_max" value="60.0" />
    <param name="output_minl" value="-40.0" />
    <param name="output_maxl" value="40.0" />
     </node>
    </group>
</launch>
I am sure, I don't make any change in path of ros_workspace. I am run for the same packages before the update and they work and after the update don't work. I'm sure I did not do to change anything in the my files only I've update for my ROS_packages. I tred rosmake agin for the same packges and I get the follwing:
[ rosmake ] rosmake starting...
[ rosmake ] No package or stack specified.  And current directory 'move_monsun' is not a package name or stack name.
[ rosmake ] Packages requested are: []
[ rosmake ] Logging to directory /home/amory/.ros/rosmake/rosmake_output-20130703-172136
[ rosmake ] Expanded args [] to:
[ rosmake ] ERROR: No arguments could be parsed into valid package or stack names.
In my .bashrc there the path of ROS
source /opt/ros/groovy/setup.bash
export ROS_PACKAGE_PATH=~/ros_workspace:$ROS_PACKAGE_PATH
export ROS_WORKSPACE=~/ros_workspace
And roscd is working. Any ideas thanks
Originally posted by underwater on ROS Answers with karma: 21 on 2013-07-03
Post score: -1
Comment by Lucile on 2013-07-10:
Is it still not working ? Did you try to reinstall everything from scratch ?
Comment by underwater on 2013-07-11:
Yes, I install fresh ROS and I get the same problem.May be the problem in path of ROS but I written as above.
Comment by Lucile on 2013-07-11:
Did you check rosdep version ? Command line is rosdep --version I had the same kind of problems as yours with a new ROS install and it apparently came from the fact that rosdep wasn't up to date.
( 0.10.21 version)
Ok, rosdep is ok then. But I do not think you have to add ROS_PACKAGE_PATH and ROS_WORKSPACE to your .bashrc since some other files are called from setup.bash to set them up. Plus, the path you set for ROS_PACKAGE_PATH seems wrong to me because it doesn't lead to stacks and share folders.
My path ros_workspace is /home/amory/ros_workspace
And in .bashrc is the follwing :source /opt/ros/groovy/setup.bash export ROS_WORKSPACE=~/ros_workspace export ROS_PACKAGE_PATH=~/ros_workspace:$ROS_PACKAGE_PATH. What is wrong ?
Comment by Lucile on 2013-07-12:
My mistake. I mixed up ROS_PACKAGE_PATH and ROS_WORKSPACE. It doesn't seem to come from your path definition. Seems like your problem is somewhere deeper in your ROS system. Maybe some tool is broken ?
Comment by felix k on 2013-07-21:
Please stop 'updating' your question to push it to the top!
Obviously, the aren't any ideas. Be more precise, post the exact directory layout with important files, place a echo $ROS.. right with the roslaunch etc. You are using a rosbuild package, right? Do you have a CATKIN_IGNORE file in your package?
Comment by underwater on 2013-07-21:
/opt/ros/groovy/share:/opt/ros/groovy/stacks:/home/amory/ros_workspace
yes I ues rosbuild package and I don't have a CATKIN_IGNORE file in my package
Uhm, with the export lines you posted the path could not result to what you posted above. Please ensure your question. - And run roswtf from inside your package.
it work finr, Package: move_monsun Static checks summary:
Found 2 warning(s). Warnings are things that may be just fine, but are sometimes at fault
WARNING You are missing core ROS Python modules: bloom -- rosrelease -- WARNING You are missing Debian packages for core ROS Python modules: bloom (python-bloom) -- rosrelease (python-rosrelease) --
================================================================================ Beginning tests of your ROS graph. These may take awhile... analyzing graph... ... done analyzing graph running graph rules... ... done running graph rules
Online checks summary:
Found 1 warning(s). Warnings are things that may be just fine, but are sometimes at fault
WARNING The following node subscriptions are unconnected:
  • /rosout:
    • /rosout
4 Answers 4
This could be related to ros-infrastructure/rospkg/issues/39.
Originally posted by gvdhoorn with karma: 86574 on 2013-07-04
Comment by felix k on 2013-07-08:
I could confirm that. With the update my rosbuild package I had used make eclipse-project with broke launching and removing CATKIN_IGNORE helped.
Hi,
what kind of build system do you use? If you use catkin, did you source the setup file?
Greetz Sonne
Originally posted by Sonne with karma: 76 on 2013-07-03
Comment by underwater on 2013-07-03:
I use rosmake and ROS Groovy with Ubuntu 12.04 LTS and Ubuntu 13.04 and I get the same problem for both version of Ubunto
Comment by Sonne on 2013-07-03:
Ok, I thought it could be the same problem like I have. But I use catkin. Have you tried to build your package again?
I just have tred and I get the following :[ rosmake ] rosmake starting...
You need to include the move_monsun directory in the ROS_PACKAGE_PATH.
but move_monsun is a package where in the ros_workspace ~/ros_workspace/move_monsun
Comment by Lucile on 2013-07-03:
is your ros_workspace still in ROS_PACKAGE_PATH ?
yes, I am sure
Comment by Lucile on 2013-07-08:
Are all you packages concerned by this problem ? I am dealing with a quite similar issue with a new ROS installation.
Comment by underwater on 2013-07-09:
Yes, all packages.
Comment by Lucile on 2013-07-09:
Ok, then we might be struggling with the same troubles. I am trying to reinstall from scratch in order to understand what went wrong. I'll keep you up
Ok, here's my question : http://answers.ros.org/question/66797/ros-installation-failed I finally got it working. I hope the answer will help you
Taken from the wiki
For a package to be considered a catkin package it must meet a few requirements:
The package must contain a catkin compliant package.xml file
That package.xml file provides meta information about the package
The package must contain a CMakeLists.txt which uses catkin
The exception to this rule is that catkin metapackages do not have a CMakeLists.txt file
There can be no more than one package in each folder
This means no nested packages nor multiple packages sharing the same directory
I think you might be missing some files. I had a similar problem once and it was solved through this. Check if you have all these files and follow the following tutorial correctly
http://www.ros.org/wiki/ROS/Tutorials/CreatingPackage
If it still does not work, you might have to change the ROS_PACKAGE_PATH
Post score: 6
Comment by gvdhoorn on 2013-07-18:
Just to be clear: while certainly helpful in making sure the OP has the proper files for a catkin package, this particular error was caused by a problem in ros/mk and catkin. See ros/issues/20 for more information.
