I have an application that needs a XBee and another module to be turned on and off digitally via a microcontroller.
The Setup is 2 XBee's and an application board is connected to the Microcontroller. On PowerON I need 1 Xbee and the Microcontroller to come on and do its routines. After the uC gets the signal from the Xbee (wirelessly from a baseStation) the board has to turn on the other XBee and application board. And when the operation is over, the XBee and Board is to be powered back down. I dont want to put them in sleep or low power state, just power both those devices off.
I was thinking of using a relay. But i cannot find a 3.3v 1A SMD Equivalent system. I am looking for a SMD type of footprint to go on a very compact board.
What options do i have?
The XBee needs around 1A Power and the Application board 500mA.
XBee sleep mode is supposed to be less than 10uA, so (if you can get it working) then use that.
A P-FET on the high side can be used to turn off anything, you'll need to drive it with a signal transistor to switch it from the mcu - e.g. here or google for FET high side switch.
  • $\begingroup$ Ok so i can use a Transistor -> MOSFET -> To control the Power Pin of the device boards. Thats good. Thanks :) I'l find a equivalent MOSFET and Transistor. Just curious, is there a driver IC available like that to do the job? $\endgroup$ Commented Jan 5, 2015 at 6:57
