Hey,
I'm trying to install the pcl1.7 from https://github.com/ros-perception/perception_pcl.git (the groovy-unstable-devel) in ubuntu 12.04 64 bits with ROS Groovy.
I has still using the rosbuild system, but it appears that the pcl git is allready made for catkin. So i created a catkin workspace as the the tutorial, clone the git to the src dir, and making catkin_make i get this:
Base path: /home/joao/catkin_ws
Source space: /home/joao/catkin_ws/src
Build space: /home/joao/catkin_ws/build
Devel space: /home/joao/catkin_ws/devel
Install space: /home/joao/catkin_ws/install
#### Running command: "cmake /home/joao/catkin_ws/src -DCATKIN_DEVEL_PREFIX=/home/joao/catkin_ws/devel -DCMAKE_INSTALL_PREFIX=/home/joao/catkin_ws/install" in "/home/joao/catkin_ws/build"
-- Using CATKIN_DEVEL_PREFIX: /home/joao/catkin_ws/devel
-- Using CMAKE_PREFIX_PATH: /home/joao/catkin_ws/devel;/opt/ros/groovy
-- This workspace overlays: /home/joao/catkin_ws/devel;/opt/ros/groovy
-- Found gtest sources under '/usr/src/gtest': gtests will be built
-- Using CATKIN_TEST_RESULTS_DIR: /home/joao/catkin_ws/build/test_results
-- catkin 0.5.65
-- BUILD_SHARED_LIBS is on
-- ~~  traversing 2 packages in topological order:
-- ~~  - pcl (plain cmake)
-- ~~  - pcl_ros
CMake Error at /opt/ros/groovy/share/catkin/cmake/catkin_workspace.cmake:88 (message):
  This workspace contains non-catkin packages in it, and catkin cannot build
  a non-homogeneous workspace without isolation.
  CMakeLists.txt:48 (catkin_workspace)
Invoking "cmake" failed
What should i do? I've read the tutorials and it didn't give me a answer.
Thanks
Originally posted by jcc on ROS Answers with karma: 200 on 2013-06-27
" and catkin cannot build a non-homogeneous workspace without isolation." -> use catkin_make_isolated
Originally posted by MichaelKorn with karma: 1480 on 2013-06-28
Comment by Mobile_robot on 2014-02-25:
Thanks that was really helpful
