Hi all,
my goal is to navigate a robot (locally - in odometry frame) using one laser scanner. Moreover I will have some additional restrictions - areas where the robot should not go. I found here two related questions (please let me know if I missed any):
Generating artificial sensor data seems to be sufficient but bit hacky in my opinion... Is this something which might be solved using layered costmaps? Or is there any other good approach? Thanks in advance.
Originally posted by ZdenekM on ROS Answers with karma: 704 on 2013-06-27
As the author of the first question and layered costmaps, yes, layered costmaps are a good solution for the problem.
Originally posted by David Lu with karma: 10932 on 2013-06-27
Comment by ZdenekM on 2013-06-27:
Ok, thanks for hint. Is there any documentation or examples how to work with layered costmaps?
Comment by David Lu on 2013-06-27:
This is the best I can point you to at the moment: http://ros.org/wiki/costmap_2d/hydro
Here's an example layering a static map on top of your usual obstacle + inflation local costmap
local_costmap_params.yaml
local_costmap:
  plugins:
    - {name: static_map, type: "costmap_2d::StaticLayer"}
    - {name: obstacles, type: "costmap_2d::ObstacleLayer"}
    - {name: inflation, type: "costmap_2d::InflationLayer"}
  global_frame: odom
  robot_base_frame: base_link
  transform_tolerance: 5.0
  update_frequency: 5.0
  publish_frequency: 2.0
  obstacles:
      observation_sources: laser_scan_sensor
      laser_scan_sensor: {sensor_frame: base_link, data_type: LaserScan, topic: scan, marking: true, clearing: true}
More details on the types of layers supported can be found here:
Originally posted by Rufus with karma: 1083 on 2020-04-23
