hello, we cannot get any information, when we try to connect our C++ listener to the existing, working Python Publisher. Codes are given below.
Publisher
import roslib; roslib.load_manifest('razor_imu_9dof')
import rospy
import serial
import string
import math
from time import time, sleep
from sensor_msgs.msg import Imu
from razor_imu_9dof.msg import RazorImu
import tf
grad2rad = 3.141592/180.0
rospy.init_node("node")
pub = rospy.Publisher('imu', Imu)
pubRaw = rospy.Publisher('imuRaw', RazorImu)
#print pubRaw
#epub = rospy.Publisher('imuRaw', Imu)
imuMsg = Imu()
imuRawMsg = RazorImu()
imuMsg.orientation_covariance = [999999 , 0 , 0,
0, 9999999, 0,
0, 0, 999999]
imuMsg.angular_velocity_covariance = [9999, 0 , 0,
0 , 99999, 0,
0 , 0 , 0.02]
imuMsg.linear_acceleration_covariance = [0.2 , 0 , 0,
0 , 0.2, 0,
0 , 0 , 0.2]
default_port='/dev/ttyUSB0'
port = rospy.get_param('device', default_port)
# Check your COM port and baud rate
ser = serial.Serial(port=port,baudrate=57600, timeout=1)
#f = open("Serial"+str(time())+".txt", 'w')
roll=0
pitch=0
yaw=0
rospy.sleep(5) # Sleep for 8 seconds to wait for the board to boot then only write command.
ser.write('#ox' + chr(13)) # To start display angle and sensor reading in text
while 1:
    line = ser.readline()
    line = line.replace("#YPR=","")
    line = line.replace("#YPRAMG=","")   # Delete "#YPR="
    #f.write(line)                     # Write to the output log file
    words = string.split(line,",")    # Fields split
    #wort5 = float(words[5])
    #print wort3, wort4, wort5
    if len(words) > 2:
        try:
            yaw = float(words[0])*grad2rad
            pitch = -float(words[1])*grad2rad
            roll = -float(words[2])*grad2rad
            # Publish message
            imuMsg.linear_acceleration.x = float(words[3]) # tripe axis accelerator meter
            imuMsg.linear_acceleration.y = float(words[4])
            imuMsg.linear_acceleration.z = float(words[5])
        #print imuMsg.linear_acceleration.x, imuMsg.linear_acceleration.y ,imuMsg.linear_acceleration.z
        #epub.publish(imuMsg)
            imuMsg.angular_velocity.x = float(words[9]) #gyro
            imuMsg.angular_velocity.y = float(words[10])
            imuMsg.angular_velocity.z = float(words[11])
        except Exception as e:
            print e
        q = tf.transformations.quaternion_from_euler(roll,pitch,yaw)
        imuMsg.orientation.x = q[0] #magnetometer
        imuMsg.orientation.y = q[1]
        imuMsg.orientation.z = q[2]
        imuMsg.orientation.w = q[3]
    #time.sleep( 2 )
    #print imuMsg.orientation.x, imuMsg.orientation.y, imuMsg.orientation.z, imuMsg.orientation.w
        imuMsg.header.stamp= rospy.Time.now()
        imuMsg.header.frame_id = 'base_link'
        pub.publish(imuMsg)
    print imuMsg #Gibt alle Sensorwerte in einer Art Tabelle aus
        # Publish Raw message from Razor board
        imuRawMsg.yaw = yaw
        imuRawMsg.pitch = pitch
        imuRawMsg.roll = roll
        pubRaw.publish(imuRawMsg)
    #print imuRawMsg
ser.close
#f.close
Subscriber
#include "ros/ros.h"
#include "std_msgs/String.h"
void chatterIMU(const std_msgs::String::ConstPtr& msg)
  ROS_INFO("I heard: [%s]", msg->data.c_str());
  ros::init(argc, argv, "listener");
  ros::NodeHandle n;
  ros::Subscriber sub = n.subscribe("imu", 1000, chatterIMU);
  ros::spin();
  return 0;
Could you please say, what we do wrong. According to this tutorial http://www.ros.org/wiki/ROSNodeTutorialC%2B%2BPython subscriber/publisher does not depend on the source language, as we understood. Thank you.
Originally posted by roman27 on ROS Answers with karma: 5 on 2013-06-26
You are right: it doesn't depend on the source language.
First of all, you're publishing an imu message, but you're subscribing to a std_msgs::String. It'll probably fuss at you for that.
Once you fix the message types to be the same, I'd suggest using the rostopic command line tool to echo what your publisher is publishing and publish dummy messages to your subscriber. That way you can test and debug the nodes independently.
Originally posted by thebyohazard with karma: 3562 on 2013-06-26
Post score: 4
