What is a good website for buying 1.5V continuous motors? I'm looking to build a clockwork robot but I cannot find a motor small enough to fit inside my power box and I don't want to mount it outside of the box. I have a 1" by .75" space that the motor needs to fit into. I have found a few websites but they look sketchy and none of them have good reviews.
Pager motors will most likely do the trick. You can find some on Robotshop for example, with correct specs. This one is manufactured by Solarbotics.
$\begingroup$ It's torque will be reduced as compared to its nominal voltage, but yes it can still turn at 1.5V. $\endgroup$ Dec 27, 2014 at 19:54
Maxon motors are quality motors for industrial automation, their catalog is here - http://www.maxonmotor.com/maxon/view/catalog/
The 320173 fits in your dimensions ( assuming the 0.75" is diameter ) and is nominally 1.8V. New ones are around a hundred times more expensive than the cheap pager motors, but rated at 2W rather than 50mW.
You can get Maxon motors second hand on ebay (the ones I got were for N-gauge model locomotives- they were 12mm diameter x 19mm 12V 1.2W - the 118429 but with a easily removed gearbox on ebay as 139885 ), though you're probably better sizing the machine around the motor you can afford rather than trying to get a particular model.
Though I'm not sure why a clockwork robot needs an electric motor - surely it would be an electric robot!
