I have found a continous control in the following form:
$$ u(s) = \left( K_{p} + \frac{K_{i}}{s} + K_{d} \frac{N}{1 + \frac{N}{s}} \right)e(s) $$
but since I need it to "convert" in a digital control I need something like:
$$ y_{k} = y_{k-1} + q_{0}e_{k-1} + q_{2}e_{k-2} $$
or everything that I can use in a digital way. Is there any algorithm to achieve such transformation? Actually the problem is the term $N$ in the equation. At first I thought that it was a simply PID controller but the N term is far from my understanding
Thank you very much and happy Christmas!!
  • $\begingroup$ Where have you found it, and why do you think it is what you need? The derivative term looks unusual. What is N? $\endgroup$ – Eugene Sh. Dec 25 '14 at 3:53
  • $\begingroup$ In this document link on page 43 $\endgroup$ – Dave Dec 25 '14 at 8:52
  • $\begingroup$ Same question as Eugene Sh. This looks like a PID controller, with an unusual term for the derivative term. The link you gave is not working. $\endgroup$ – Alexandre Willame Dec 25 '14 at 18:35
  • $\begingroup$ The parameter N regulates the filtering on the derivative term to cut off high-frequency noise and to make the derivative feasible, of course. Read the bible of PID (page 76) for reference. $\endgroup$ – Ugo Pattacini Dec 25 '14 at 19:55
You should take a look at the Tustin transformation to get the bilinear mapping between s-domain and z-domain. You'll also find examples therein.
Once you're provided with the description of your transfer function in z-domain, it's straightforward to derive the formula in discrete time domain.
Given $$ \frac{Y}{U}=\frac{b_0+\ldots+b_{m-1}z^{-(m-1)}+b_mz^{-m}}{a_0+\ldots+a_{n-1}z^{-(n-1)}+a_nz^{-n}}, $$
you'll obtain $$ y_k=\frac{b_0u_k+\ldots+b_mu_{k-m} - a_1y_{k-1}-\ldots-a_ny_{k-n}}{a_0}. $$
|improve this answer|||||
  • $\begingroup$ How should I deal with the $N$ term in the first formel? $\endgroup$ – Dave Dec 25 '14 at 18:49
  • $\begingroup$ Uhm, it seems you're not so familiar with PID control then... This is one of possible reference (page 76). Before rushing headlong into the problem, always recap some useful pieces of theory :) $\endgroup$ – Ugo Pattacini Dec 25 '14 at 19:57
