When I try to rosmake pcl17 or pcl17_ros i get the following error:
/usr/bin/ld: cannot find -lsensor_msgs
I have the sensor_msgs package. Does anyone have any ideas as to why this would happen?
Originally posted by mdedonato on ROS Answers with karma: 61 on 2013-06-14
Comment by MichaelKorn on 2013-06-17:
We need more information. Can you describe what you did step by step? Do you use fuerte?
Not knowing what version of ROS you are using or seeing the full error message, this problem might already be solved here in this answer: How do I use pcl 1.7 with groovy?.
Originally posted by Kevin with karma: 2962 on 2013-06-14
Comment by Artem on 2013-06-15:
I've just compiled this one git clone https://github.com/ros-perception/perception_pcl.git -b groovy-unstable-devel. You have to change pcl-1.6 to pcl-1.7 in .//pcl/doc/tutorials/content/walkthrough.rst to successfully build other packages that depend on pcl.
Comment by MichaelKorn on 2013-06-16:
Do you have installed sensor_msgs? On Ubuntu you can do this with "apt-get install ros-groovy-common-msgs".
Comment by Artem on 2013-06-17:
BTW after I compiled PCL, rosbuild cannot compile costmap2d anymore, it cannot find pcl.
@Art: you should use catkin
I do use catkin to build catkin packages including pcl. However, rosbuild packages also uses catkin packages. I don't know why when I build pcl-1.7, costmap2d does not find it. I don't have the log now, I rolled back to pcl-1.6 now. Actually, let me try to build pcl-1.7 in overlay workspace.
