I want to use brushless for my line follower.
The problem is most ESCs don't accept more than 400-500 updates/s due to the characteristic of steering signal.
Is there a way to overcome this with a custom flash or am I out of luck?
    $\begingroup$ Under what circumstances is a >500 updates/second rate needed for line following? How many km/hr do you anticipate the line follower moving? $\endgroup$
    – Mhz4.77
    Dec 29, 2014 at 1:03
  • $\begingroup$ Under any competion-winning ones. It has to move at least 4m/s at times. $\endgroup$
    – Chumanista
    Dec 30, 2014 at 10:51
The thing i was looking for turned out to be the KISS ESC: http://flyduino.net/KISS-ESC-2-4S-18A-v11_1
It has an update speed of op to 2000Hz due to it's own control method called oneshot125.
Here are some off the shelf ESCs which claim to give 400Hz + update rate
1000Hz http://www.hobbyking.com/hobbyking/store/__39708__Afro_ESC_30Amp_Multi_rotor_Motor_Speed_Controller_SimonK_Firmware_.html
600Hz http://www.amain.com/next-level-30-amp-multi-rotor-esc-w-simonk-firmware/p265104
499Hz http://www.helipal.com/storm-multirotor-30a-opto-esc.html
Normally SimonK firmware should give you some scope to play around for your requirements. You can refer following links
https://github.com/sim-/tgy
http://www.rcgroups.com/forums/showthread.php?t=1513678
