Good morning everyone,
I've been trying to export a model from SolidWorks to MoveIt, but I haven't been successful. I have an industrial arm in an assembly file and was trying to use the sw_urdf_exporter.
I followed all the steps described here: exporting assembly to URDF, but it hasn't worked correctly so far. My issue is that, when I export the file with the joints corrdinate systems all in the origin of the base_link, the arm is imported correctly in MoveIt, but the parts, instead of rotating in their place, rotate around the whole robot body. On the other side, when I put the coordinate systems in the right place, in the joint, they rotate around the right point, but are expanded as if two times as far as they should be from the origin of base_link.
Has anyone tryed this or has any idea of what might be the problem?
In this dropbox folder I have 2 videos of what is happening:
https://www.dropbox.com/sh/slw1mz05lo919l5/d5RlhA1t6z
Feel free to ask any questions you might have!
Thank you,
Tiago Pimentel
Originally posted by t.pimentel on ROS Answers with karma: 385 on 2013-06-12
